Originally posted by rollingstash:
Yeah, whatever you say man, anyhow, my MTX amp puts out like 325 watts at 14.4 which is not its peak draw, meaning this is an average output for a given voltage just like RMS. so what i was trying to say is that the Infinity in question was probably getting a lot more that 360 watts from the ppi amp that i am assuming was rms because he probably matched the rms rating of his sub with the rms rating of an amp. I'm not an electrical engineer but i do know about car audio (certainly not everything).
If you really want to know the actual power of your amp, play pink noise (most DB drag cd's have a track with it) You will need a digital voltmeter, set it on AC. Play the track at the maximum clean output. Take a reading at the amps speaker terminals. At 4 ohm mono to get 325 rms watts that amp would have to produce 42.89V AC. Here is the formula for those calculations:
volts AC squared (times itself) / impedence of the load the amp is seeing x .707 (value of rms rating)
In your case it would be this:
42.89 x 42.89 (1839.5521)/ 4 (assuming 4ohm mono)= 459.88 Peak watts x .707 =325.14 rms watts.
Now this is just a generalization you would need an oscilliscope to actually figure out 100% dead on results. You can also do this at one dedicated frequency (20hz, 50hz...etc) these results will vary since the woofers impedence changes at differecnt frequencies and in length of testing the coil will heat up changing its impedence curve as well.
It was never mentioned which amp you do have, after checking the MTX site their new 75x2@4ohm amp does 120 x 2@14.4 and 300x1 @4ohm mono with 12.5 and then 425x1 at 14.4. (thunder 8302) So what you are saying is that your model MTX amp goes from 150 watts at 4 ohm mono to 325 mono watts with just a 2 volt difference?
Like I said before, I'm not trying to piss you off, lets be realistic though. MTX is a good amp I just think many people do not realize that real clean power will not hurt any woofer, once you add distortion ( adding the "loud" Button and turning up the bass control) that is when voice coils get fried. As long as everyone is happy with there system, that is all that matters
