Posts: 2,517 |
I doubt anyone carries Toyo Proxes T1S's or RA1's with the 7.5" wheels. Plus the ones I get will most likely end up being custom so I'm on my own. But these are very good suggestions!!
EDIT: 1300 BEEEYOTCH!
Posts: 1,603 |
I can probably get away without having to roll the fenders. The problem is the little part of the fender that sticks out on the inside of where the bumper meets the wheel well and mounts to the fender. I may just cut off the extra metal inside and see what happens.
Pete...
2004 Mercury Marauder 300A
Black Clearcoat/Dark Charcoal LEATHER
DOB 10/31/2003
DOP 1/2/2004
www.mercurymarauder.net
Posts: 119 |
here's mine:
stock svt suspension on an E0
225r45-17 dunlop sp9090s (great tire BTW)
on 17x7 ET45 Mille Miglia Evo5 and i NEVER EVER EVER rub.
i want to go to 18s since this isn't my "performance" setup, but i'm so happy with not rubbing and running 225s.
oh, and i didn't roll the fenders at all even though i do have that huge lip sticking out where the rear bumper meets the fender.
Posts: 148 |
So is this coming to a wrap yet. Will it or someone answer the question... "Can I put on a set of 18x7.5 with 42mm offset and not rub, if so what size tires should i get to make it happen?"
Posts: 2,676 |
I would def go with a 40 series tire for sure. 225 or 215/40.
215 would be the safest bet. Yeah, do that, 215/40. Tirerack has 2-4 tires that meet that criteria as well.
Suneil
Posts: 1,785 |
Originally posted by pupet89440: So is this coming to a wrap yet. Will it or someone answer the question... "Can I put on a set of 18x7.5 with 42mm offset and not rub, if so what size tires should i get to make it happen?"
I am running a 18" x 7.5" with 47 offset and Have never rubbed with 225/40/18. I personally think you will rub no matter what with that offset. just my .02
I take that back. With my old rims and 2 buddies in the back seat I did rub leaving the jack in the box.
Just a Plain SE.
AKA Big Country
I maybe path914's B**** now, but wait until he needs his clutch done. We will see WHO is WHO's B**** then!
Posts: 101 |
Originally posted by ssmumich00: Here's the answer: if you're supersizing past 215 on a 17 or 18 in rim, TRIM DOWN the sidewall. 1314 is cool with 235/40's because 40's should prevent the rub, but I wanted something meaty to protect my rims and mistakenly got the 225/45's. . .and that's why it rubs only on the right rear.
Bingo! 225/45 yields a sidewall height of 101.25mm. 235/40s yield a sidewall height of 94mm. In this case, it sounds like 7mm made all the difference in what rubs and what doesn't.
Time to start shopping for some 235/40s!
- Trent
MY99 CSVT black/tan
Enkei RS7 (bronze)
SHOShop Y pipe
Eibach Pro Kit
Quaife LSD
Posts: 187 |
so to sum it up, i want to put some 17's on mine. what offset would bring the tire out to the edge of the fender like a BMW. i am looking at 17x7's or 17x7 1/2. thanks
HORSEPOWERIC= ALL THE POWER IN THE WORLD STILL AIN'T ENOUGH
98 silver svt, modified y,ngk(indexed),pulley's,shifter,redline. future plans,custom borla exhaust, bilstein/h&r, rota slipstream 16x7 13 lb"s
Posts: 4,639 |
well a 42 offset should look good. 45 might give u some rub cuz it'll put it really close to the fender edge. this is for a 7" wide wheel. 7.5 just makes it easier to rub so maybe avoid 45 offset and use 42 or 40
Hugo AIM:omegazodiac
Posts: 187 |
thanks for the info. are the REV wheels any good? i have been looking at getting those model 10(40mm offset) or model 1(42 mm offset). but they come with 205/40/17. i would like a 215/45/17. any suggestions. thanks
