Posts: 6 |
Will a factory Cd player plug into my 98.5 SE Sport with "premium sound" AM/FM/Cass without any problems?
Posts: 494 |
Your question is a little vague.
If you want to replace the cassette deck for the CD deck, I don't see why not. If you want to have both the cassette and CD deck, I doubt you'll be able to.
If you need the cassette deck, you could buy an aftermarket changer and an fm modulator, or a tape deck/cd changer from the same company to avoid the need for an fm modulator (plus you'll be able to get rid of the stock unit).
I'm no expert on this, but I doubt you can have both ford decks at once.
Brian
1998 Mystique LS V6 ATX - Satin Green/Grey Leather Moonroof - Ford Remote Starting System 885s for fogs - Fogs with Parks JVC KD-SH99 MP3 - Pioneer TS-A6865s in the doors JVC 12-Disc Changer "Sometimes I'm good, but when I'm bad, I'm even better."
Posts: 536 |
As long as you're sure that your car has premium sound with the stock amp, it should work with no problems...
Brian
Brian 1999 Contour SVT Green KKM, Dual 40 Series Flowmasters, SHO Shop Y Pipe, Removed Resonator, B&M Edge Shifter, Stainless Grills, Painted Rear Reflector, Green Underbody Neons, JSP Grand Touring Spoiler, Eibach Suspension, 18" Katana Tezzas, Pirelli Rubber, Graphics by http://www.clubconceptz.com brian8064@hotmail.com
Posts: 3,237 |
Originally posted by fhealey: Will a factory Cd player plug into my 98.5 SE Sport with "premium sound" AM/FM/Cass without any problems? I'll sel you my Factory CD player for $20. It isn't even a year old. ------------------ Regards, Anastazi sarigia@aam.com "Computer games don't affect kids. I mean if Pacman affected us as kids, we'd all run around in a darkened room, munching pills and listening to repetitive music." 2000 Silver Frost SVT #1126 of 2150 SHO Shop UDP's Aerospeed Pod/High-Energy Intake YoDude Y-pipe Twin 4" Supertrapps 2.5" Dynomax Bullet Resonator Bosch +4's/Taylor Spiral Pros ES Motor Mount Inserts APR 53" DTM Spoiler H&R Springs Pioneer DEH-P7000R, TS-6975's, TS-6855's, Ultimate SB10BS, MTX Blue Thunder PRO502 http://www.geocities.com/qikslvrsvt
Posts: 536 |
Damn, I'll buy it for $20 even though I don't need one...I sold mine on ebay for $100 a little while ago.. ------------------ Brian 1999 Contour SVT Green KKM, Dual 40 Series Flowmasters, 3.5" tips, Removed Resonator, B&M Edge Shifter, Cuzo Headlights, Clear Corners, A6 Side Markers, Silver Grills, Painted Rear Reflector, Eibach Suspension, 17" Konig Tantrums, Toyo Rubber. brian8064@aol.com
