F
fhealey Offline OP
F
Will a factory Cd player plug into my 98.5 SE Sport with "premium sound" AM/FM/Cass without any problems?
Your question is a little vague.
If you want to replace the cassette deck for the CD deck, I don't see why not. If you want to have both the cassette and CD deck, I doubt you'll be able to.
If you need the cassette deck, you could buy an aftermarket changer and an fm modulator, or a tape deck/cd changer from the same company to avoid the need for an fm modulator (plus you'll be able to get rid of the stock unit).
I'm no expert on this, but I doubt you can have both ford decks at once.
Brian
1998 Mystique LS V6 ATX - Satin Green/Grey Leather
Moonroof - Ford Remote Starting System
885s for fogs - Fogs with Parks
JVC KD-SH99 MP3 - Pioneer TS-A6865s in the doors
JVC 12-Disc Changer
"Sometimes I'm good, but when I'm bad, I'm even better."
As long as you're sure that your car has premium sound with the stock amp, it should work with no problems...
Brian
Brian
1999 Contour SVT Green
KKM, Dual 40 Series Flowmasters, SHO Shop Y Pipe, Removed Resonator, B&M Edge Shifter, Stainless Grills, Painted Rear Reflector, Green Underbody Neons, JSP Grand Touring Spoiler, Eibach Suspension, 18" Katana Tezzas, Pirelli Rubber, Graphics by http://www.clubconceptz.com
brian8064@hotmail.com
I'll sel you my Factory CD player for $20. It isn't even a year old.
Regards,
Anastazi sarigia@aam.com
SHO Shop UDP's
Aerospeed Pod/High-Energy Intake
YoDude Y-pipe
Twin 4" Supertrapps
2.5" Dynomax Bullet Resonator
Bosch +4's/Taylor Spiral Pros
ES Motor Mount Inserts
APR 53" DTM Spoiler
H&R Springs
Pioneer DEH-P7000R, TS-6975's, TS-6855's, Ultimate SB10BS, MTX Blue Thunder PRO502
Regards,
Anastazi
Father of the Aussie Bar
anastazi.sarigiannis@aam.com
Damn, I'll buy it for $20 even though I don't need one...I sold mine on ebay for $100 a little while ago..
Brian
KKM, Dual 40 Series Flowmasters, 3.5" tips, Removed Resonator, B&M Edge Shifter, Cuzo Headlights, Clear Corners, A6 Side Markers, Silver Grills, Painted Rear Reflector, Eibach Suspension, 17" Konig Tantrums, Toyo Rubber.
brian8064@aol.com
Brian
Moderated by  dnewma04_dup1
