Hi Guy's I was wondering if anybody had this problem before and knows how I could fix it. I just got my new sony CDX C90 CD player installed in my car with a Rockford 600 a5 amp. Now when ever I put the fade in the middle the amp goes into protection mode and no sound comes out of the speakers but when I fade it to the front it stays on no matter what volume. What do I do?
Well, I really don't know where to begin other than making sure all of the wiring is done correctly. Could one of the rear speaker wires be shorted? Maybe there is no signal going to the rear speakers when the fader is set to the front and the problem isn't being caused. Start with those rear speaker wires and report back.
Like dnewma04 said, it is probably in the wiring. Although It could be the amp. Try playing with the rca's. remove the rear rca's and try it then the front etc..
Hardest hitting SVT in Oklahoma and maby the U.S.
1998 Silver Contour SVT
17x7.5 Quantum Tech S-13 Rims
Nankang 215/45/17
Lo Tech A Pillar pods
Resonator Removed
Panasonic CQ-DFX701U
MobileTV Hi-Fi VCR
MA-Audio DVD Player
MobileTV 6.4" LCD
(2)Xtant X415 subs
(2)JBL BP1200.1
(2)A/D/S 250MX
Phoenix Gold XS160 Components
Audiobahn crossover
Auto Meter Phantom Gauges
Bullit Fuel Door
B&M Short Throw Shifter
Ichibahn REV Series Steering Wheel
Sounds like a bad ground to me. It's likely that your amp isn't getting enough power and shutting down. Or the chasis may have a ground and cannot be bolted to a metal frame. My kenwood 401 has to have spacers put in to the bolts don't touch the chasis or else it is instant shut down. Ironical enough the 501 i have doesn't.
If it's true that we are here to help others, then what exactly are the others here for?
F
F
Also make sure you check the gain on the amp.....when it fades to middle maybe it's turning up and shutting off....
Hey SILVERSVT26....Have you had your car db tested...???
Chad Williams
chad5160@usa.net
'99 SVT Frost Silver #812 of 2760 Born on Jan. 12, 1999
KKM, No Res, BNM White HVAC, Shaved, Apline CDA-7864, Boston 5x7 Coax's, Original Punch Power Amps (Gold/Silver 240 4ch & 100 2ch), Audiocontrol X-Over, 3 MTX Thunder6000 10's, Stinger Power/Signal, Optima Red Top in Trunk..More to come
Chad Williams
chad5160@excite.com
Moderated by  dnewma04_dup1
