Okay, after (2) P0171 last two weeks I finally bought the Electrical cleaner at Autozone. They didn't have the B12 stuff, so I had to buy a different brand.
Monday I put the CTA apart and I brought inside the house the MAF & IAT. I kept cleaning the parts throughout the day. I also cleaned the wire connectors (both on the sensor and on the car side).
Tuesday: I took the train, and I had to drive only 7 minutes top. Funny thing: I go hard on the car and I hear NO PINGING !!!!
Can you believa that ?? NO PINGING !! For the first time EVER !!
I thought the car wasn't warmed up enough, so I keep my expectations low.
Today I drove to work. 20 miles. i step on it and NO PINGING again !!!!
I can't believe it. I didn't even thought about cleaning the MAF and fixing the pinging problem. After all, I've been asking for years about the pinging and NO ONE ever mentioned MAF/IAT sensors !!!!
Is the car playing with me or the pinging is really GONE ????
Does that make any sense ??? Could eitehr the MAF or the IAT be causing the pinging ?????
Later
Anything is POSSIBLE... sowing the seeds of love"
CEG road warrior
CEG road warrior
Well never thought of it....if you get a faulty reading from the MAF it may (or seems to) throw your a/f off. At least that is what I am thinking.
thats the thing.
NOBODY, the whole CEG, never thought about it.
And that scares me: maybe the ping has not really gone away.....
I don't even know if the problem was the IAt or the MAF.. I cleaned both at the same time.
Is there any chance that either of them could be the cause of my pinging ??
Yes,
If the hotwire on the MAF is dirty, it will indicate less air in entering the engine than is true.
Computer adjusts fuel to match the incorrectly smaller volume of air.
O2 sensor then indicates lean P0171 IIRC.
An engine running lean will run warmer, and have a greater tendancy to ping.
Fix the lean condition, and it is reasonable that the ping goes away.
HTH,
TB
"Seems like our society is more interested in turning each successive generation into cookie-cutter wankers than anything else." -- Jato 8/24/2004
Thanks man !!
Very reasonable. I mean, I didn't think about this, Ford didn't think about this, CEG didn't think about this...
You know... like a Physics problem: after the problem is solved everybody is like: "wow.. how didn't I think about this??"
Oh, I thought about it, I just visit the Zetec area of the board much.
Even though my 1st Contour was a 96 GL with a Zetec.
I had your very issue and yes, my pinging went away when the MAF was cleaned.
TB
web page
web page
web page
There were many other cases but the last one is significant.
Running lean does not cause much pinging in a stock engine unless there is annother problem. Reduced EGR, Octane creep, and timing problems top the list.
F
F
The Cleaning of the MAF is what did it. On my 1994 Mustang Gt it was a common problem for those cars to ping with little timing advancement and 93 octane fuel.
I would always pull the sensor for the MAF out of the housing and clean it with a cue tip and some rubbing alchohol.
Remember..... All you guys running the K&N type filters are making this even more of an issue. Because those filters are "charged" with the oily substance.....It will attract more dirt to these sensors. Therefore they will need to be maintained more often.
When I cleaned the MAF on my mustang, not only did it clear up the pinging but it also picked up over half a second in the quarter mile. No joking. This was an older car with more miles but....Just an example of how bad it screwed up the a/f mixture.
1998.5 Silver Frost SVT Contour One-Off BBS RX wheels, Tinted windows
My friend had a K&N drop in air filter on his 2000 mustang and I kept telling him to clean it. Well, guess what he got... an all new MAF and intake manifold cleaning (all covered under warranty).
Hmmm, I gotta try that. My car has pinged for the last 2 years or so.......
-Ken V. 1998.5 SE Praire Tan Zetec ATX psycho_bass@hotmail.com Roush springs Roush rear sway bar BAT struts 17" Millie Miglia HT3 and a ton of subtle asthetic mods
