Where is the negative cable placed when the car is jumped? Most likely NOT on the battery, correct? You problem is most likely a bad ground. Check your wiring and your negative battery cable for signs of corrosion.
1999 Red / Tan SVT #1969 of 2760 Built 4/21/99 K&N, DMD, FMS Wires, ES Insert / Bushings, PF End Links 17" FSVT 5-Spokes Factory Spoiler 35% Tint All Around
