Whenever you open the door with the key in, that sound is there. DING DING DING DING DING! It gets sooooo annoying when im trying to work on the car. Especially when im wiring up my cd player and I need to leave the key in to listen to the speakers. Its even worse if I am somewhere around the car with friends, and I want to put on some music and open a door or two (need key in ignition).
SOOOO I came up with an idea to install a switch for the tone. This way I can leave the door open, and just flip the switch under my dash to make it shut up. And I can just turn it on again later. The problem is, when I looked at the speaker itself, it is directly attatched to the fusebox, and I dont want to screw around with wiring in the fuse box. I thought that I can just take apart the switch in the doorway that clicks in the tone. I thought that I could just rewire it and put in a flip switch so that I can just cut the power to it whenever I want. When I cut the wire, the other end fell back into the hole. Now I cant find it. No matter how much I dig from the inside, or wherever, I CANT FIND THE DAMN WIRE! It was white with a black stripe, and I noticed a white/black stripe wire coming from the fuse box, but I really dont think its the same one because it is quite thicker. I noticed another white/black stripe wire going to the power mirror controls. Is there a place I can get a wiring diagram from, or does anybody know where this wire leads to and from? I hope somebody out there understood what I just wrote, because I need to find this thing. If pics are required, then I can maybe take them tomorrow.
