Posts: 77 |
does anyone know what i can to to stop the vibrations from the subs. i can tell the rear brake light located behind the back seats is moving pretty good, and i think something one the dash thats right next to the windshield. anysuggestions??
to a none related subject. has anyone cut a hole in the rear dash and put a speaker grill over it so more air will move from the trunk to the passenger area?? think it would inprove anything?
Posts: 261 |
When I installed my 2 15s there was a lot of vibrations. I finally got a sheet of foam, and placed pieces of it under the rear deck to reduce the brake light's movement. I also had to place a few pieces under other parts of the deck. It was done by squeezing the pieces through the holes in the trunk, and took about a week of finetuning. I also had to remove the plastic pieces in the rear 1/4 panels that cover the vents. It doesn't rattle at all now. The liscence plate and rear bumper is a different story...
------------------ Black is beautiful. '99 Contour SVT.
...always clean, always mean.
[This message has been edited by Sadeeq (edited March 13, 2001).]
Black '99 Contour SVT. Stereo Upgrades & Cosmetic Enhancements ...Always clean, Always mean.
Posts: 707 |
To fix your liscense plate first make sure you have no liscense plate frame...May look cool but will ALWAYS rattle. Then just buy a sheet of dynamat and dynamat the back of the liscense plate...It fixed my rattle..Hey Sadeeq...You just said "I also had to remove the plastic pieces in the rear 1/4 panels that cover the vents."...What are you referring to? I am trying to cure my rattles too!!!!! ------------------ Chad Williams chad5160@usa.net'99 SVT Frost Silver #812 of 2760 Born on Jan. 12, 1999 KKM, No Res, Shaved, Apline CDA-7864, Boston 5x7 Coax's, Original Punch Power Amps (Gold/Silver 240 4ch & 100 2ch), Audiocontrol X-Over, 3 MTX Thunder6000 10's, Stinger Power/Signal, Optima Red Top in Trunk..More to come
Chad Williams chad5160@excite.com '99 SVT Frost Silver #812 of 2760 Born on Jan. 12, 1999
Posts: 253 |
if you pull the carped away from either side of the rear of your trunk, you will notice a vent. it has a plastic grating and a plastic gutter to keep water from leaking into your trunk. behind the grating (looking from the inside) there is a rubber flap that covers the hole. when air pressure is increased or decreased in the car, these flaps open. when a large sub is moving the air in your trunk the pressure causes these rubber pieses to flap loudly in a fart like manner. put your head next to each side of the trunk whil playing oyur subs and you will hear it. i used needle nose plyers to rip the top part of the flap out, but left the bottom and the watter gutter in. no more fart.
don't drink and drive.
Posts: 230 |
I did the same thing with the gutter things also I put rubber spacers between my liscence plate and car no more rattle cheaper than dynamat 35 cents each
Posts: 923 |
To kill license plate rattle, I used a couple mouse pads. Go to staples and pick up a big cheap-o pad, and cut it into sections, i put one piece under each screw mount, and little squares of it all over the rest of the plate (or cover the whole back of the damn thing). I stuck it on with good ol' elmers glue. Make sure you get a cloth-faced pad, and not the laminated face ones.
------------------ 98 Mystique LS -Audio: Alpine CDA-7844 head unit; 4 RF FRC1257 2 way's; 1 12" Kicker Solo Baric, powered with a Rockford Fosgate power 500M amp -Performance: SVT exhaust; B&M edge shifter -Prettification: Aluminized door cups and other pieces; Hiper super plazma 9006 low beams; yellow fog light bulbs
Posts: 707 |
Thanks for the info stash....I have only had my stereo done for a week and a half and am going after sounds one by one....Now my trunk won't fart anymore....I will have to fill in for it!!! tehe ------------------ Chad Williams chad5160@usa.net'99 SVT Frost Silver #812 of 2760 Born on Jan. 12, 1999 KKM, No Res, Shaved, Apline CDA-7864, Boston 5x7 Coax's, Original Punch Power Amps (Gold/Silver 240 4ch & 100 2ch), Audiocontrol X-Over, 3 MTX Thunder6000 10's, Stinger Power/Signal, Optima Red Top in Trunk..More to come
