Well, I found a clean path coming out of the front cover just below the crank pulley. Looks like the water pump is leaking. So, I need a water pump, timing belt, whatever pullies are under the front cover, and a tensioner...correct? If there is anything else, could someone add it to the list here? I'll order the parts Tuesday and hopefully get this thing sealed up in the next week or two.
On another note, the condensed water from the AC is dripping insode the car. I smeared a bunch of silicone around the gasket and housing hoping to seal it off. It looks lke a MAJOR job to do it the right way, i.e. pull it apart and replace the leaking gaskets/housing. My only concern is that it will leak under the insulation/carpeting that is passes through on it's way out of the car. Time will tell...
Could Ford make a harder car to work on?
