racertb Offline OP
OK everyone, I have two questions:
1. Which brand is "better" and why?
2. If my 10" sub requires a sealed box of .8, then:
a) a sealed box of .86 by Subzone should be just right, correct?
b) how would this sub requiring .8 perform in a sealed box by Q Logic rated at .65?
c) would adding polyfill to the .65 box make the sub (rated at .8) perform better? Or, how would the polyfill effect the sub?
Please let me know so I can make an informed decision--Thanks in advance.
Ted Bush
2000 T-Red SVT
#1027/2150, Built 12/20/99
racertb@yahoo.com
your best bet is to always stay the closest to the recomendation, but if you can only get your hand on the smaller box then yeah stuff it w/the poly fill sh-t. but you wouldnt get any better results from the smaller box. either be equal or less quality.
pauli18@aol.com for questions
99 green svt
asp udp
b-n-m short throw
kkm intake
n the list grows steadily
I think the subzone box is the brand that Louisw is using in his car. One advantage is that the angle on the box he has fits perfectly against the back seat.
Always pick the larger enclosure if there isn't one that is perfect (this only applies to sealed enclosures, ported enclosures need to be perfect). Actually, the subzone box probably is perfect. You can usually count on a 10 or 12" sub to take up about 10% of the box volume which would result in .78 cu ft for the subzone box. Check the sub mfg recommendation on box size to see if it already recommends using polyfill.
Polyfill will allow you to undersize a box by about 15%. The problem with an undersize box is that it builds up more backpressure which in turn heats up the voice coil. Hot voice coils result in dynamic compression which will cut your maximum output, sometimes pretty substantially.
The other bad result of a small box is a higher Q. The higher the Q, the sloppier and boomier the bass.
Moderated by  dnewma04_dup1
