Posts: 98 |
Hey all, got a question. What would be the best year Focus to get a motor out of for an engine swap? And what are the differences in them, besides the Focus SVT. Thanks all.
Touring '97 Tour, ZETEC ATX
Posts: 21,653 |
Difference is you may be able to fit a few aftermark parts easier, but that's about it. IF you can also use the focus oil pan,etc. and then a header would be easier to fit. I'd think a 2000 or 2001 would be good.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 2,483 |
No reason do do an engine swap. Just need to swap a few items.
Frank McCoy aka Mod-deth aka Mid Life Crisis aka SVT Doood aka mcgainer is a SCAM ARTIST
Pre98 Zetec - Some Mods
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by SleeperZ: No reason do do an engine swap. Just need to swap a few items.
Yep.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 502 |
Which parts would you specifically recommend?
Paul's NEW '01 Focus ZTS
45k miles and counting!
K&N drop-in and Silverstars
Posts: 3,465 |
I hear '63 was a good year
2003 Subaru WRX some mods
Even if you don't have the answer, you certainly have to admire the problem.
aka ZetecRacing
Posts: 111 |
Originally posted by janostak: Which parts would you specifically recommend?
a full exhaust including headers. expensive but worth it! it will perform and sound better. A cheap way to have a better header is to burn the [censored] out of the catalytic converter with a blowtorch. this loosens up all that [censored] that restricts exhaust flow. do that to the szecond one to and put 2.25" pipe and the muffler of your choice and your set. 9mm plug wires to so you can take advantage of the accel coil pack and dbl platinum plugs. if you dont it will burn the cheap ones. mass airflow sensor, throttle body, high torque cams and adjustable cam gears. the list goes on. my advice would be 1 save alot of money 2 look around for the parts you want and develop a plan of attack 3 buy with the intent of actually using
1998 Contour GL
Zetec I4 w/auto
MODS:
Fog lights and Mesh grills
Soon to come are a set of
Rims and Yokohama AVS ES100's
Come see at
cardomain.com
Posts: 3,465 |
Originally posted by JD60538: A cheap way to have a better header is to burn the [censored] out of the catalytic converter with a blowtorch. this loosens up all that [censored] that restricts exhaust flow. do that to the szecond one to and put 2.25" pipe and the muffler of your choice and your set.
1 there is only 1 cat on the Zetec 2 you realize how big the cat is on our car? 3 with such a large volume of area for heat to build on it will do more harm to performance than it would help
aka ZetecRacing
Posts: 2,483 |
Get a ported 2000-2001 Focus intake manifold. That year is a better design, plus it is port matched to the head & TB, and all the extra material has been removed. Plus it will allow the use of aftermarket Focus TB's.
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by SleeperZ: Get a ported 2000-2001 Focus intake manifold. That year is a better design, plus it is port matched to the head & TB, and all the extra material has been removed. Plus it will allow the use of aftermarket Focus TB's.
Need me one of those.
Hector
257HP/259TQ
160HP/141TQ
