Posts: 535 |
what kind of problem and repair am i looking at possibly any ideas would be great , it has only had the hard shifting happen 2 times in the past 3 weeks and only for about 15 minutes sut the car off let it sit and everything has been fine ??
2006 KIA RIO LX 5-speed
2003 Escape 3.0L wifes
Posts: 535 |
Posts: 912 |
very expensive if you bring it to a shop.
wouldnt suggest doing unless you were mechanically inclined, about 250-300 bucks in parts.
I have the same problem..Everytime that it begins to happen, just turn the car off and wait 5-10 seconds and then start it back up. It will be fine again to go!
Jason
00 Audi S4, 2.7 Bi-turbo quattro
01 S10 Xtreme, 4.3l
98' Contour SE with some mods
96 Cavalier (beater)
Posts: 3,944 |
Your torque convertor is stuck in the off position. In other words, it is not locking. It could be the solenoid block, but most likly the piston located in the valve body.
Most likely time for a good ole rebuild, but search around for some of Mercmans articles. He did his himself.
Phillip Jackson
`98 Mystique LS
262K+ and counting...
ATX rebuilt @ 151K
Posts: 535 |
thanks guys would a tranny power flush do any good thats never been done just the old drain and fill in the past , or would that not make a difference?
Posts: 912 |
wouldnt make a difference at this point. your supposed to do that every 12-24k miles. you are aleady at the consequence of what happens when you dont do that...once your here you cant go back!
Jason
01 S10 Xtreme, 4.3l
Posts: 463 |
Logan00,
You need a new TC and a rebuilt and modified valve body. The parts will run about $400-500. You will have to do the work yourself (the install) since it is unlikely that you will find anyone that will be willing to do a partial repair.
Now for whatâ??s actually going on. The converter bypass valve (controls fluid pressure to the TC and TC lock up) is a defective design in the CD4E. Two other valves are also poorly designed and suffer premature ware and are responsible for controlling hydraulic pressure in the tranny. As the valves ware the pressures that control clutch engagement and TC lock up drop. This causes the clutch plates in the TC to drag and slip during lock up (just like ridding the clutch). This causes the disks to fail. With the TC not locked the fluid is heated to a high temp in side the TC. A second defect now comes into play, during lock up flow to the trans cooler is reduced. With no flow and an unlocked converter the fluid can boil! When you come out of lock up the hot fluid is sent back into your trans damaging the rest of the unit.
As a safety, the PCM detects the slippage in the TC and sets code 1744. It also sets the internal control pressure to 90 PSI in hopes of overcoming the problem, this results in Bang Shifts. This alerts the driver to the problem. Each time you shut the car off the PCM resets this 90PSI condition. This is why shutting the car off and restarting seam to fix it for awhile.
Why did I tell you all of this? Well if you keep driving your car you will destroy the rest of the tranny. If you stop and get it fixed now you can save big bucks. Also, flussing and additives will not help so donâ??t waste your money on them.
Oh, and donâ??t kick yourself over this. No amount (although Iâ??m sure to get an argument over this statement) of tranny maintenance can prevent this failure. It is built into the design of the VB and oil paths. My tranny was maintained and driven responsibly and my VB was shot at 87k mi.
What ever you do, make sure that your new VB has been updated with all the Sonax valves. SK-JR alone will not help at this point.
jeff
have you fixed your ford lately?
Posts: 3,944 |
Taking from my experience and being backed up by Mercman, I will add to this a little...
If you were to continue driving the car under these conditions, for an extended period (I had to go almost 4 months before getting the money to get mine fixed), you will first crack the forward drum, followed by the forward sprag. The cracking of the drum will destroy your Forward and Direct clutch packs. The failure of the forward sprag will be followed by the GEARS!!! ~shiver~
Logan, If you can perform the repairs yourself soon, you will save yourself a ton of money. I couldn't, so I had to spend a little over $2000 to repair mine.
The vavle body can be removed without pulling the tranny, but to get to the TC you can easly pull the engine to gain access to that.
Any other questions, you can of course give a holla!!
P.S. Just be glad that your TC did not lock in the "On" position. It would not stay cranked in that case. Now that would be a real bummer.  Good Luck
Phillip Jackson
`98 Mystique LS
ATX rebuilt @ 151K
