#729964 08/24/03 11:44 PM
U
U
Alright, so I have been needing to gut my bank 1 precat for a good while now. Today, I decided to do it. Simple enough right?
Wrong....
I had one freaking stud break on me, and it has turned everything to crap! On the bank 2 precat, the stud located closest to the oil pan.
I knew something like this would happen since everything under there is rusted to *bleep* and back. So before I started, I ran out to the parts store to got some bolts and nuts just in case.
My problem is this... I cannot for the life of me, which right now is not adding up to much, get the darn stud out of the flange. I knew it was pressed in, but !!!!
I really don't see a way to get a small press, sort of like a ball joint puller, on the flange. So how can I get it out? I have beat on it until my arms are like rubber and I have started thinking about paying the neighbors to take turns at it! Actually beating on it is not doing much good other then flaring the end of it out.
And yes, of course I have used a lubricant and it was not WD40. It was some stuff called Moovit by Lloyds. It worked great on helping break the others loose.
Phillip Jackson `98 Mystique LS 262K+ and counting... ATX rebuilt @ 151K "This storm has broken me, my only friend!" RIP Dime
#729965 08/25/03 12:02 AM
Hi Phil,
A couple of ideas...Try PD Blaster as a solvent. I removed every one of the screws from my 1985 Nissan PU's exhaust manifold's heat covers. Many of these were very rusted after 18 years. I sprayed them all down a couple times and let them sit for a few hours. Every one screwed right out...no breakoffs or tight ones. Can buy at Wally-World for approx $4.00 a can. BEST stuff I have ever used. Comes out in an orange foam.
Next, sometimes, one can make use of a dremel tool to make a slot for a screwdriver blade or repair a bolt enough for a socket again. Yours may be beyond that....
Your internet handle interests me. Did or do you work for Unisys Corporation? Just curious...
Good Luck, Duane in KC
#729966 08/25/03 12:07 AM
You are talking about the stud at the collector on the headers, right? Well I had my headers completely off so I had better acess to the studs, butI just shot the stud good with WD-40 and used vise grips to unscrew it, and it came out. Remember lefty loosy, righty tighty.
1999 CSVT-Black 15.8@89mph Driver for hire. PM me.
#729967 08/25/03 12:28 AM
or you can drill it out and re-tap the hole.
#729968 08/25/03 12:52 AM
U
U
This is what I am talking about...
I got this image from the how-to over at fastcougar.
dak507, naw I don't work for Unisys. I do work for Xerox though. When picking a screen name for the site, my wife was talking to me about something to do with the company Unisys at the time, so I just used it. Sort of how I did with my geocities account - I really like the song YYZ by Rush and the year that album was released, that song was on, was in 81. The rest as they say is history, sort of like my arms right now...
#729969 08/25/03 01:17 AM
Oh man....This just looks like an all day fun fest.....
'04 Ecotec Cavi 140hp/150tq Fabbed intake. Header Coming, DRL's disabled, X-Drilled/slotted rotors coming....Man you really are fast. You were hauling a$$ when I passed you RB&LB causing problems in Huntsville
#729970 08/25/03 01:37 AM
You may be able to drill it out. Other than that, I have no idea. Bummer.
"...first he's gonna s*!t, then he's gonna kill us." 1999 Contour SVT Retrojunk.com
#729971 08/25/03 01:50 AM
Good luck!!!
..."Carrying enough heat to bury June"... [image]http://groups.msn.com/_Secure/0RwDWAocUTN7RfnKXmlhRFapYMDigykSDqTyfBkadWj*JkZzSSVi1nYJWu5juvIwUs9AWx2Wg*6w9SaFRYbkZ5TUUqqXw7pMELkoTKdHHcdY/Cameron.gif[/image]
#729972 08/25/03 02:19 AM
U
U
Originally posted by Self Scientific:
Good luck!!!
Since all mine ran out today, I will need all I can get!!
I wet the stud down again before I finally gave up and will wet it again in the morning before I leave for work. When I get home I will be the living crap out of it and walk away with either the stud in my hand or a y-pipe in my near future...
#729973 08/25/03 02:39 AM
Take it to an exhaust shop. They can torch it, and then pound it out.
Chris G. ~ 98 Mystique LS ATX
