Alright, so I have been needing to gut my bank 1 precat for a good while now. Today, I decided to do it. Simple enough right?
Wrong....
I had one freaking stud break on me, and it has turned everything to crap!
On the bank 2 precat, the stud located closest to the oil pan.
I knew something like this would happen since everything under there is rusted to *bleep* and back. So before I started, I ran out to the parts store to got some bolts and nuts just in case.
My problem is this... I cannot for the life of me, which right now is not adding up to much, get the darn stud out of the flange. I knew it was pressed in, but
I really don't see a way to get a small press, sort of like a ball joint puller, on the flange. So how can I get it out? I have beat on it until my arms are like rubber and I have started thinking about paying the neighbors to take turns at it! Actually beating on it is not doing much good other then flaring the end of it out.
And yes, of course I have used a lubricant and it was not WD40. It was some stuff called Moovit by Lloyds. It worked great on helping break the others loose.
