Page 2 of 4 1 2 3 4
Regarding the 8" Free air sub --
where is the 6.5" hole in the deck you were talking about? does the woofer protrude into the cabin? or is it under that material by the rear window?
Thanks
Brian
1998 Mystique LS V6 ATX - Satin Green/Grey Leather
Moonroof - Ford Remote Starting System
885s for fogs - Fogs with Parks
JVC KD-SH99 MP3 - Pioneer TS-A6865s in the doors
JVC 12-Disc Changer
"Sometimes I'm good, but when I'm bad, I'm even better."
It's on the passenger side. If you look from in the trunk, you'll see it.
btw, i'm still looking for a good option for an 8". Just want to be able to give some good options to people when interested in free air.
I have pioneer 6x8's in the doors of my car. i had terrible rattles in my doors untill i got a 10" polk sub and took all the bass off of the door speakers. my trunk doesn't rattle at all either so i'm all set. I think pioneer makes an 8" free air sub too. i've thought of just adding 6.5" component midbass drivers to the rear deck. yeah i know a lot of work, blah, blah, blah i've got the tools and the time just not the money. so yeah, that's what i think.
don't drink and drive.
APT Offline
My woofer is mounted under the deck, with a spacer that has an enlarged hole. I cut away the padding, but not the carpet over the deck, so you cannot see it from inside the cabin. You can only see it move at higher volumes.
As Dave said, the hole is on the right side, look in the trunk. A second one on the drivers side would be difficult because of the center 3rd point seatbelt.
I started to do that with the decklid but I was having trouble with getting the cardboard away from the carpet. My main goal was to make a bass port for my 2 12's. Well I got frustraited when trying to cut out the cardboard without stretching the carpet. Well, when I got done, it looked like $hit. So I just cut out the hole. I found an older speaker grill that is 6 1/2 in size which is the exact hole size. I mounted the speaker grill on there. At first I was like, what the heck have I done to my car. Well, I get nothing but compliments on it now. Looks real sharp and it really helps the bass get into the cabin where it belongs. It's kinda funny, when I have some girls in the backseat with longer hair, their hair flops around when the bass hits.. Cool new feature..
99 SVT Silver Frost, Knauberized Doors, Xenon Headlights, TH Fix, KKM Filter, Resonator Removed
--STEREO MODS--
Clarion HU with DSP module, RF 5x7's all around, 2 RF Power 12's,
2 MTX tweeters in dash,
1 MTX 4160 for highs,
1 MTX 2160 for subs, 1 Farad Capacitor, 1,600 Cold Cranking Amps worth of battery power..
culguy76@hotmail.com
99 SVT Silver Frost
Knauberized Doors, Xenon Headlights, TH Fix, KKM Filter, Resonator Removed, B&M Short Throw Shifter, Fidanza Flywheel, RAM HD Clutch
--STEREO MODS--
Clarion HU with DSP module, RF 5x7's all around, 1 Kicker Sole-Baric L7 Woofer, 2 Kicker Comp 12s
1 RF 200ix for Solo-Baric
1 MTX 2160 for Comps
1 Farad Capacitor
OEM battery & optimus gel cell..
Culguy76@hotmail.com
If I were to run the single 8" free air sub in the rear deck where the existing hole is (behind the right rear passenger), would it fill the car with enough bass? Let me rephrase -- does the sound fill the car nicely, or does the bass seem to come from that area of the car and filter out? I don't want the right side of the car to have more bass than the left side, and I also don't want to slice and dice the rear deck, either... I like the idea of having a hidden 8" sub. Also, please explain how an 8" will fit around the 6.5" hole back there?
Brian
JVC 12-Disc Changer
If you cross the sub over at about 100 hz or below, you'll have a hard time placing it with your ears. You'll have to bottom mount the sub. Otherwise, it won't fit. I would recommend making a baffle out of 3/4 material (MDF/plywood) and mount the speaker to the under side of the wood. This will give the speaker the room to move if you end up with a high excursion sub.
Hey Dave --
By "bottom mount" to a "baffle", is this what you mean?
I attach the 8" sub to a piece 3/4" MDF, with an 8" diameter opening. Then I attach the MDF to the rear deck, effectively using the MDF as a "spacer" or a 'step' between the speaker itself and the rear deck.
What would I use to attach the MDF to the rear deck without it looking silly... nuts and bolts?
Thanks again.
Brian
JVC 12-Disc Changer
That is basically what I was describing. I have never done this so maybe someone else can comment on how to attach. I would think that by removing the material from the top of the deck, you could attach it with some screws/bolts from the top.
Dave
Page 2 of 4 1 2 3 4
Moderated by  dnewma04_dup1
