Posts: 2,483 |
Generally speaking, advancing the intake gear 1-2 degrees, and retarding the exhaust cam the same amount, will net some gains. You can also try setting them at the drag strip, but only if your a very consistent driver. Dyno is really the way it should be done, but I would dyno cam & cam gears at the same time. Just install the gears at 0,0 for now.
Frank McCoy aka Mod-deth aka Mid Life Crisis aka SVT Doood aka mcgainer is a SCAM ARTIST
Pre98 Zetec - Some Mods
Posts: 192 |
so can they be used with turbo....probally just checking
whats the average you contours set your intake and exhaust cams? what kind of gains do you see
CEG road warrior
CEG road warrior
Posts: 17,248 |
Got the cam gears from Focus Central (had them in red). Had them at 0,0 for now set them at +10,+10 and there is a noticable difference in low and mid range power. Waiting for more mods ![](/ubbthreads/images/graemlins/wink.gif) before I spend the $100 an hour to tune them.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 2,483 |
+10 on both gears for my car makes it run like sh*t. -10 on both, samething. Definatel yget cams before tuning cam gears, and yeas they can be used with a turbo.
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by SleeperZ: +10 on both gears for my car makes it run like sh*t. -10 on both, samething. Definatel yget cams before tuning cam gears, and yeas they can be used with a turbo.
You have a chip correct?
Hector
257HP/259TQ
160HP/141TQ
Posts: 2,483 |
Posts: 192 |
so you guys would recommend getting new cams with the cam gears? what kind of gains should i see with the cams? and where do i go to get rods and pistons for this engine? i need something strong enough for 18 psi....
Posts: 2,483 |
At 18PSI, you'll need a stronger block as well. Esslinger makes just about everything for our engine, but it is pricey. No reason to pay to have cam gears tuned ($50-$100 per hour) untill you get cams. I would expect a 15+HP gain with both.
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by SleeperZ: At 18PSI, you'll need a stronger block as well. Esslinger makes just about everything for our engine, but it is pricey. No reason to pay to have cam gears tuned ($50-$100 per hour) untill you get cams. I would expect a 15+HP gain with both.
I need more HP!
Hector
257HP/259TQ
160HP/141TQ
Posts: 2,483 |
Originally posted by LoCoZ: I need more HP!
Don't we all!
I got my set of cams sitting in my garage.
Won't be going in for quite awhile though.
Still in need of;
stage 1 Esslinger head,
ported 2001 Focus intake manifold,
and a header.
Dyno tune & reburn chip, and calling it quits.
And of coure maybe a few little things here and there.
Should be ~215 crank HP.
