Posts: 192 |
ok guys i just ordered 1...ford racing 9mm plug wires 2.....UDP crank pulley 3....overdrive pulley for alternator
my intake is being made and almost have a header bought....what else can i buy besides the adjustable cam gears(cause my mechanic said there too hard to put and and a waste of time) can i buy while i have the zetec engine out of the car?? does anyone make any other pulleys????? or if you know were i can buy a header for a contour zetec, focus or cougar for under 250 dollars????
thanks guys!!!!!!!!!!!
Posts: 3,465 |
Originally posted by anthonyconstant: what else can i buy besides the adjustable cam gears(cause my mechanic said there too hard to put and and a waste of time)
1 find a better mechanic..... hard to put on when the engine is out of the car WTF is that that would make it easy to put them on and waste of time WTF.... have you seen D Davis' dyno before and after the cam gears?
2 if cam gears are too hard then I can suggest nothing else to do to your car that would be easy other than a cip for the computer.
header for under $250 well that might be doable..... but you will still be spending about that much to have it modded to fit a contour.
2003 Subaru WRX some mods
Even if you don't have the answer, you certainly have to admire the problem.
aka ZetecRacing
Posts: 192 |
maybe he meant cams? cause you can see the camgears when the hood is poped?no? arent they right above the crank pulley and run off the same belt?
the header i need cause working with the rusted exhaust manifold will be a [censored] to weld....you have any sites for a cheap header i just need one temporary for NOPI cause i am going turbo after that...
Posts: 648 |
Originally posted by anthonyconstant: maybe he meant cams? cause you can see the camgears when the hood is poped?no? arent they right above the crank pulley and run off the same belt?
no they do not run off the same belt. you have two belts in the car. your timing belt, which the cams use and your serpentine belt which goes with your crank pulley.
speaking of timing belts guys...i think its time for a new one for me. Mine is walking and is hitting something in the engine bay. (sorry to hijack but this seemed like a good place to bring this up) where can i get one and how much are they? I know they are expensive but I'm just wondering if I could find one cheaper than I've seen. Let me know.
PRIME-TOUR
You're fired! I write the books here!
~Tom~
Posts: 3,465 |
well get the cam gears off and it's not much more work to remove the cams..... any if he says that cams are not worth it again FIND A NEW MECHANIC, or better yet take and automotive class or two and be your own.
aka ZetecRacing
Posts: 1,085 |
Engine out..? Aluminum flywheel and New clutch.
2012 Lotus Evora
95 Mystique MTX - GONE 395,000 Kms
--------- Both Zetecs
'97 Contour Mtx - stock - GONE
Posts: 192 |
Originally posted by WestCoastAjax: Engine out..? Aluminum flywheel and New clutch.
yes the engine and trans are setting on the floor...its an automatic....any direct links to the item would be great.....i am glad this site is here lots of info on an engine i am ignorant on..lol
Posts: 1,085 |
Originally posted by anthonyconstant: Originally posted by WestCoastAjax: Engine out..? Aluminum flywheel and New clutch.
2012 Lotus Evora
Posts: 192 |
so what kind of gains can you expect from cam gears(am i right in assuming theres two? cause zx2tuner sells one, while CTA sells them in pairs) can i use the cam gears with turbo...what is the best degree to set them at??? any one have any pics of there engine bay with the cam gears?
Posts: 8,301 |
Setting the gears with a dyno is the only accurate method. Not using a dyno, you will never know just how much you gained or lost, if you set them wrong.
-Ken V.
psycho_bass@hotmail.com
