Posts: 208 |
I just Bought a new set of 12" Polk MOMO subs...anyone have any experience with the Polk Momo Line or maybe just the polk series....I'm still braking mine in so they still sound like ****! but I'm hopeing they will be great subs.....They should be for 399.99 bucks a shot....
------------------ Black 99 SE_SVT 2.5L MTX 17Inch TSW REVO (Silver) 225/40/17 Toyo (Z-Rated) ASP Underdrive Pulley Energy Suspension Mounts 20% Tint (Sides and Rear) Ground Control Coil Overs 2.25 Exaust Dual Vortech Mufflers Removed Resonator Brospeed Tips PIAA BMW Style Headlights PIAA ION Blue Fog Lights Smoked Blk. Side Markers Superchip(Not Working) ITG Intake BAT Air Inlet Pipe Kenwood P907 Touchscreen 2 12Inch Polk MOMO Subs 1400 Watt Kicker Amp 4 Gauge Wire 3 Full Monster Farads 4 Clarions 5x7 2 Ways Clifford Bullet 4 Alarm Remote Windows Tilt Sensor Motion Sensor Impact Sensor Ignition Kill
Black 99 SE 2.5L MTX 17Inch TSW REVO (Silver) 225/40/17 Toyo (Z-Rated) Energy Suspension Mounts 20% Tint (Sides and Rear) Koni Adjustable Struts H&R Springs 2.25 Exhaust Dual Vortech Mufflers Removed Resonator Brospeed Tips PIAA BMW Style Headlights PIAA ION Blue Fog Lights Smoked Blk. Side Markers KKM Intake BAT Air Inlet Pipe Superchip B&M Shifter Kenwood P907 Touchscreen 4 10" JL Audio 10W3 900 Watt Kicker Impulse 40x4 Sony ES Amp w/EQ 4 Gauge Wire 2 Full Monster Farads 4 Clarions 5x7 2 Ways 6.5" w/ Tweeter Polk MOMO Crossover Clifford Bullet 4 Alarm Remote Windows Remote Start Tilt Sensor Motion Sensor Impact Sensor BN White Guages w/ Blue
Posts: 767 |
polk momos are some of the best subs on the market, very costly tho
------------------ 1998 E0 Ford Contour SVT *Silver Frost/Midnight Blue * New cupholders, ceg sticker =) * 9005 philips blue visions in lows * sylvannia 885 fogs * coming soon: jvc kameleon hu
1998 E0 Ford Contour SVT Built on 8/19/97 -- #3101/6535 Silver Frost/Midnight Blue * New Cupholders * CEG sticker =) * 9005 Philips BlueVisions * Sound System: Kenwood eXcelon KDC-X617 HU, RFosgate fnq514 components, RFosgate 6x9 3ways, RFosgate 12" sub, MTX 5ch/800w amp, 1 Farad Cap * Removed Ford emblems * Fogs w/parking lights and aimed up * Brushed Aluminum Style Grills all around * 205/55/ZR16 Bridgestone Potenza RE730's * Removed Headliner * Visit MY SVT website (UNDER CONSTRUCTION)*
Posts: 208 |
I just installed ine into a box with about 1.1cu and the polks only want .88cm and they should like crap at high volume....could that be it...I'm not to sure?
Posts: 208 |
Sorry my last post was barely english...That was supposed to 1.1cu for the box...the subs spec say .88cu and they SOUND like crap at high volume...where my cheaper subs didn't...so I'm curious if box air volume makes a big performance difference....
Posts: 8,142 |
With a sealed enclosure, it shouldn't make much difference...
Posts: 2,066 |
If I were you I would get a bit of R9 insulation and stuff the box with a little. Makes the bass a little more defined and tight when you have a smaller enclosure. But it will eat up more power if you lower the box volume.
Hope that helps.
Posts: 144 |
maybe it's because your aren't feeding them enough power, or clean power, you don't have a crossover, or perhaps the source signal is just crap? The MOMO subs are the best Polk makes, and Polks are some of the very best.....so it sounds like user error to me..
'98 Tropic Green Tour SE Sport V-6 ATX "I promise I wont modify it honey, it's a family car!"
Posts: 324 |
I've always heard Momos are just dressed up dxs that can handle a little more power, I hope you got some good subs, regardless $399 apiece you got hosed bad dude. You can get so much better online for far cheaper price, for example Eclipse 8812 alums, just over $300 at woofersetc.com, but regardless I hope they end up kicking ass, just think you payed way too much, but of course you've probably got a factory warranty, not flaming you, just think you should have shopped around and got a better deal.
Posts: 208 |
LOL....I would never pay that much for a SUB...I used to work at Goodguys Electronics....and I still have friends that work there...I got both Polk MOMO subs and a 3 year ESP for 425.00....ain't cost great.......I was just quoting the 399.00 price tag versus how they were performing...not like a 399.00 sub..thats for sure......Update though...I stuffed the box with a ****LOAD of cotton and lined the box with another coating of sealer.....they sound a lot better but still kinda weak at high volume a bit of distortion...but they are not broken in yet either....and I need to tune my AMP and EQ still....I know the power sinal is clear..I tested them today I run through caps...So i had 14.25 going from battery to CAPS and 14.55-14.88 from the CAPS to the amp...and with my amp it says 920 WATTS@14.25 volts..so They are getting plenty of power...just think they need to be broken in a little better..... cause my 220.00 pioneers were much better sounding but they were broken in...so I'll give these another week and if not exchange them for a new set..and if those suck too...then I'll just return them for some JL Audios or something....not sure what I'll go for... [img] http://albums.photopoint.com/j/View?u=1543312&a=11698864&p=41590084&Sequence=0&res=high[/img] ------------------ Black 99 SE_SVT 2.5L MTX 17Inch TSW REVO (Silver) 225/40/17 Toyo (Z-Rated) Energy Suspension Mounts 20% Tint (Sides and Rear) Ground Control Coil Overs 2.25 Exhaust Dual Vortech Mufflers Removed Resonator Brospeed Tips PIAA BMW Style Headlights PIAA ION Blue Fog Lights Smoked Blk. Side Markers ITG Intake (Backorder) BAT Air Inlet Pipe Kenwood P907 Touchscreen 2 12" Polk MOMO Subs 1400 Watt Kicker Impulse 4 Gauge Wire 2 Full Monster Farads 4 Clarions 5x7 2 Ways Clifford Bullet 4 Alarm Remote Windows Tilt Sensor Motion Sensor Impact Sensor Ignition Kill
Posts: 161 |
How do you have your subs wired? Are the subs sharing air space, or are they separated? What is the RMS of your amp? NOT PEAK, but RMS. Also, what guage wire are you running to the subs?? MOMO's, even though VERY over priced, are good subs, they shouldn't sound like crap.
1997 Contour SE
