Iā??m going to use the FL300 oil filter. It is a shorter version of the FL1 style that came with the remote filter. I am also going to remove my factory lines and re-plum the whole deal. I donā??t like using barbed fittings and hose clamps on oil lines or cutting into good lines. For the flexible sections I am going to use braided high pressure (per-made) hose assemblies. The hard line I will use 3/8 OD steel tube and bend and flair it myself. I will let you know when I find a suitable location for the filter. Itā??s too hot to work today.
jeff
