#726558 08/20/03 11:20 PM
my check engine light came on the other day and i was hearing a ticking in my engine. i went and had a test run on my car and said cylinder 4 was misfiring. i did a tune up changing the plugs and wires which had not been done since the car was manufactured and my car has 94,000. the car runs a hell of alot better but the cylinder is still knocking. anyone have any suggestions on what i can to fix it or what it might be?
1998 Mercury Mystique LS Dark Blue, Leather, 5spd, Duratec 2.5 L V-6 And Am Currently Ordering A SVT Contour Touring Style Wing, And Still Looking For The Body Kit
#726559 08/21/03 12:56 AM
Bottom end starting to let go?
1999 Contour SE Sony Xplod 50x4 cd player Sony Xplod 1600 watt Class D amp 2 10" Flame-Q Audiobahns 35% tint done by Madavi's Motor Sports
#726560 08/21/03 04:27 AM
W
W
Ticking from where........top-bottom-fuel rails......?
2012 Lotus Evora --------- 95 Mystique MTX - GONE 395,000 Kms --------- Both Zetecs '97 Contour Mtx - stock - GONE
#726561 08/22/03 01:27 AM
its coming from the top left of the engine, but when im under the car i can hear it there too. i changed my oil and the 5w-30 oil i dumped was like water. i moved up to 10w-40 and added this oil lubricant. i hope it helps. let me know if u can come up with something
#726562 08/22/03 02:41 AM
Before you go nuts check the coil pack, #4 wire and plug. Arcing from a broken plug, wire, or coil can make a load ticking sound. Itâ??s best to check at night so you can see any arcing.
jeff
have you fixed your ford lately?
#726563 08/23/03 04:37 PM
thats one thing i didnt think to check. i will tonight and let u know how it goes. thanks for the idea
#726564 08/26/03 01:10 AM
i figured out what the problems was, bad rod bearings.....400$ to fix. o well atleast i will have new ones
