Posts: 645 |
Ok I admitt I'm an idiot. How do you tell what frequency of sound to go to what speakers? Is this what a crossover does? Oh yeah I think I have decided on the Boston Acoustics RX87 speakers.
[This message has been edited by Coors (edited February 15, 2001).]
Chad ----------------- http://www.1dzine.com jetski@mindless.com 98.5 SVT ? KKM Tru Rev ? Glasspack instead of resonator ? Dyno Max Super Turbo Muffler w/Brospeed 3.5" Rolled tips ? Brembo/KVR Cross Drilled Cadnium Front Rotors and KVR Carbon Brake Pads ? Blown Engine Replaced @ 41K
Posts: 8,142 |
First of all, good choice on speakers...I always seem to forget about the Bostons.
A crossovers purpose is to send the freq to th right speakers. A Crossover should not be necessary considering you are not running a subwoofer.
Posts: 494 |
Dave --
At this point you are correct. I don't believe that my taste in music requires a sub, nor do I want to use the trunk space and all of my money to do this.
Can someone tell me about the boston acoustics that Coors decided on? Are they available in Canada?
Brian
1998 Mystique LS V6 ATX - Satin Green/Grey Leather Moonroof - Ford Remote Starting System 885s for fogs - Fogs with Parks JVC KD-SH99 MP3 - Pioneer TS-A6865s in the doors JVC 12-Disc Changer "Sometimes I'm good, but when I'm bad, I'm even better."
Posts: 8,142 |
I had a pair of boston 6x9s from a few years back. At the time, the only better 6x9 on the market was the JBL 545. I generally really like BA speakers and as far as I know they are available in Canada. Their subs are, so I assume their full product line is available.
BAs are definitely worth a listen before making up your mind.
Posts: 645 |
Originally posted by dnewma04: First of all, good choice on speakers...I always seem to forget about the Bostons.
A crossovers purpose is to send the freq to th right speakers. A Crossover should not be necessary considering you are not running a subwoofer. Well not yet anyway. I put a bid in on the Infinity Bass Link. We'll see what happens. With a sub, then should I run a crossover?
Posts: 8,142 |
I'm guessing that the basslink will have the subwoofer crossover. You could add some bassblockers to the doors to cut the bass from them. A seperate crossover is probably not worth it at this point. If you start getting into a multi amp system, you will definitely need one.
Posts: 165 |
I'm sure you'll hear this a dozen more times but he Bosotn Acoustics are good speakers. I had the 5X7 in my front doors and they sounded good. Now I have the 5 1/4" component set and they sound great.
------------------ '99 SE Duratec with 5spd DTM muffler (sorry guys) Resonator removed 3 JL 10W0s driven with Fosgate 500a2 Boston Acoustics RC520 components up front with Boston Coaxial in back both pairs driven with RF 400aIV with a lightening audio cap ST200 wheels with Kumoh Ecsta 215/45/17's
Mike Silver '99 SE V6 MTX, Eibach, Koni, Res removed, Dynamax B&M, Boston Acoustics, Fosgate, JL, ST200 wheels
Posts: 983 |
JL Audio 100% all the way!!!!
------------------ Adrian Chong 1998 Vibrant White 2.0 Zetec Sony MDXC6500X (Mini Disc) "Powered By Ford" Shoulder Pads 3A Racing Pedal Covers Pre-98 Sail Panels Alpine SPS-5729 in the front JL Audio TR570-CX in the Rear Zetec Inside Sticker Replica Porsche 944 Rims (5 circle ones) CEG Sticker Super White 9006 Low Beams
1998 Vibrant White 2.0 Zetec / "Powered By Ford" Shoulder Pads / 3A Racing Pedal Covers / Pre-98 Sail Panels / Alpine SPS-5729 in the front / JL Audio TR570-CX in the Rear / Zetec Inside Sticker / Replica Porsche 944 Rims (5 circle ones) / CEG Sticker / Super White 9006 Low Beams / Euro Style Short Antenna / Broadway Wide-Angle Mirror / Painted Front Grill Vibrant White / CTA Intake / Accel Ignition Coil / Diablosport Chip / Dynomax Super Turbo Muffler / Ractive Amber Side Markers / ST200 Struts / Eibach Springs
Posts: 645 |
Thanks for your info everyone!
Posts: 618 |
I would have to suggest 6 1/2" speakers for the rear. Mount them toward the bottom of the 6X8 opening. The grill in the rear door is not centered over the opening in the door for the speaker. 6 1/2s will be pretty much directly behind the grill. I did this using Kenwood 2 ways, and I am happy with my install. As for the 6X9s in the front. Not all 6X9s will fit in the front doors! I tried to install an old set of Sonys that I have, into the front door. Didn't work. They don't fit down into the 6x8 opening enough to allow me to put the door panel back on. I think it will all depend on the size of the "basket" on the speaker. I have JBL 5X7s 2 ways in the front. I really want to upgrade these though. I get a lot of vibration in these JBLs.
------------------ Ted Garfield Hts.,OH '95 SE,Duratec,MTX,fogs w/parks,Ray's THF,rear dome,tranny cocktail,minor stereo mods.
GOD BLESS AMERICA!!!
Ted tdavidk76@hotmail.com '95 SE • DOB-4/20/95 • every option • Champagne • Duratec • MTX. Mods: Taylor wires • Bosch +4 • Eibach/Sachs Super Gas (half done) • rear BAT urethane bushings • SVT air box (thanx Dom!) • fogs w/parks • 885 50w fog bulbs • Ray's THF • rear dome • lighted moonroof switch(thanx again Dom!) • tranny cocktail • minor stereo mods. Yet to install: Front Eibach/Sachs • Front BAT urethane swaybar bushings.
