I put on a new timing belt and everything else (tensioner, guides and water pump) but the timing belt wants to slap against the plastic cover over the top of the camshaft pulleys.
It quiets down after a few minutes, but it is very annoying at first. The tensioner is pulling the belt tight because of the spring. The bolt that holds the tensioner on is not very tight (25-30 flbs.) like the manual and a mechanic recommended.
The original tensioner DID NOT have a spring!?!?
The P.O.S. (piece of crap) tensioner broke apart at 168K.
The belt actually looks OK (yes... I replaced it.)
I used a piece of angle iron to keep the camshafts in place at TDC, so they are correct in relation to one another.
What I do wonder is how much play the camshaft can have due to the pully rotating slightly on the camshaft over time...
The manual shows that you can loosen the torx bolt that holds the pulley on the camshaft and rotate the pully with a "special" tool. The piece of angle iron holds the camshafts at TDC. This would tighten the belt between the camshaft pulleys. Buttt.... I imagine that there is a degree of play designed in... why?
Also, the timing belt started slapping against the cover at about 65K miles (it now has 168K.) I am annoyed that it does it after I replaced everything.
WHY?
DB
