#722456 08/17/03 01:45 PM
mikeQQQ Offline OP
This fxxxxx moosing noise just driving me carzy, its easy to come when weather is hot and the hot tempterure in these couple days did help.its so lound just like a tornado siren that could send my neibors run for shelfter , I think Ford should have made a recall on this
#722457 08/17/03 01:52 PM
replace the IAC valve....
06 GMC Sierra 2500HD Dmax/ally 06 Pontiac G6 GT 05 CRF250R FOR SALE 06 KX65 with riding gear $2700 obo
#722458 08/17/03 02:39 PM
2
Check here. http://www.contour.org/FAQ/FAQ.php?s=probs to do the TH fix which will most likely eliminate it. If that doesn't work replace the IAC valve. Well good luck man.
Irfan Rahim irfman2000@yahoo.com 2006 Blue Nissan Sentra SE-R Spec V Former owner of a silver 2000 Contour SE Sport ATX
#722459 08/17/03 09:50 PM
V
V
Finally eliminated it for me in the following order:
"bagpipe" assembly replacement;
IAC replacement
Throttle hang fix as described in the forums.
1.5 years now without it!
#722460 08/18/03 04:59 AM
yeah, i would recommend the TH fix. This worked wonders for me. I used a pretty big hole, i think it was 1/4, but the moose has been gone ever since! I love it!
98 SVT #1652 of 6535 My SVT "If everything seems to be going well, you obviously don't know what the hell is going on."
#722461 08/18/03 06:17 AM
mikeQQQ Offline OP
How much does a
iac valve cost?
#722462 08/18/03 01:52 PM
Is there anything like this part on a Zetec-VCT L4 2.0L?
#722463 08/18/03 02:18 PM
Originally posted by mikeQQQ:
How much does a
iac valve cost?
I just tried to find a price on an IAC valve at fordpartsonline.com, but their site is down right now. In the meantime, the Throttle Hang fix costs a mere $0.30 (less in most cases) and an hours time - including getting out the simple tools you'll need.
A few folks have reported feeling a "power loss", but this is in fact not so. This is only perceived because of the change in engine behavior. I had the TH fix on my 1999 SE V-6 ATX and recently removed it. No change in power at all, just the slightest hint of resonance from the accordian tube. I may end up re-installing it again if the resonance gets any more audible.
#722464 08/18/03 06:03 PM
You dont have to deal with moosing...consider yourself lucky.
2000 SVT Black/Tan #1633/2150 (a few mods) Alpine: CDA-9835, MRV-F540, MRD-M550 PG: TANTRUM-X 6.5 COMP all around. Some people wear Superman pajamas. Superman wears Chuck Norris pajamas. CEL currently: Off
