Posts: 937 |
Originally posted by StealthWyvern: Originally posted by Kremithefrog: If all you're doing is replacing the valve cover gasket, then that is EASY.
yeah but pictures are cool!
Heck Yeah.. If I had pictures and a step-by-step page to read on Valve Cover Gaskets for my car that would the best thing ever for neebies like me getting into cars for the first time.
Posts: 1,308 |
Originally posted by TronX: Originally posted by StealthWyvern: Originally posted by Kremithefrog: If all you're doing is replacing the valve cover gasket, then that is EASY.
Ditto
97 Mystquie GS - I4 ATX died at 168K
94 Pontiac Crap AM SE - 2.3L I4 5spd
2002 Mazda Protege5 - 2.0L ATX
Posts: 21,653 |
Haynes manual is detailed enough to replace the valve cover gasket (it's way easy). You'll need a torque wrench though, so either be prepared to buy one (cost upwards of $30) or borrow one. Or hope you set the torque right using normal tools on an important part of the engine.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 1,308 |
but these pictures are more detailed... lets see you find that image quality in your manual! lol
Posts: 937 |
Originally posted by Kremithefrog: Haynes manual is detailed enough to replace the valve cover gasket (it's way easy). You'll need a torque wrench though, so either be prepared to buy one (cost upwards of $30) or borrow one. Or hope you set the torque right using normal tools on an important part of the engine.
Lol.. I need to get one of those. Any idea of what pressure one of those should be set for on this Zetec L4?
CEG road warrior
CEG road warrior
Posts: 17,248 |
To remove the valve cover all you need is a 8mm socket, 5/16 extended socket, and if it is the first time removing the valve cover maybe a pry bar.  BTW Darrel those cam gears look familiar.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 937 |
Originally posted by LoCoZ2: To remove the valve cover all you need is a 8mm socket, 5/16 extended socket, and if it is the first time removing the valve cover maybe a pry bar.
Dang.. Where do I need the 5/16 extended socket for?
Posts: 2,291 |
Originally posted by TronX: Originally posted by LoCoZ2: To remove the valve cover all you need is a 8mm socket, 5/16 extended socket, and if it is the first time removing the valve cover maybe a pry bar.
I'd say spark plugs, but you don't HAVE to remove them. Not a bad idea to take 'em out and check condition & gap, though.
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by D Davis: Originally posted by TronX: Originally posted by LoCoZ2: To remove the valve cover all you need is a 8mm socket, 5/16 extended socket, and if it is the first time removing the valve cover maybe a pry bar.
For the rear bolt on the valve cover that holds the wire for the VCT harness.
Hector
257HP/259TQ
160HP/141TQ
Posts: 2,291 |
eh...that's strange. I don't have any other bolts on the valve cover other than the 8mm that hold it on.
