DAMN!
I really do think the SVT profiles are outstanding and near impossible to beat for the power curve...
However there is no way they give 30HP much less 50HP. More like 10-12HP or 5-6% of the gross HP. Stop respecting those sources...
IMO you could see gains of up to 20HP with a very hot NA 3L or forced induction.
Now they do produce a much stronger and longer powerband though. That in itself is worth having!
Also if you could get a set of adjustable cam gears then all bets are off...
Originally posted by thestrain98:
Vortech is the only source for programming the computer once a supercharger has been installed. A superchip is out of the question. Vortech actually lays completely different IC chips on the circuit board of the computer. Then why not ask Vortech you say? Those are the guys I'm talking about with the conflicting stories. Imagine that!
Not true. Plain & simple.
Vortech does no such thing. All they ship with the kit is a GENERIC chip with a close approximation of what everything should be set at. Definitely NOT a great way to tune an engine much less one that is force fed!!!
You will want a custom chip burned. It's the TUNER that matters. Not the chip. Pick your Tuner wisely...
