Page 2 of 2 1 2
Good question. I replaced my deck and added the changer myself and found the sound to be comparable, if not better than the factory with the amp. If it is a jbl, then keep it. Why not? The amp I took out looked like crap so I junked it after asking a stereo shop if it was any good. They said it wasn't. You lucked out, I guess.
"I've got a lot to learn in so little a time. Oh well!"
Do we really have to do the rating system?
Mods: Chris Hightower-like Express Open & Close
885 fogs
& stereo stuff
I would venture to guess that he assumed it was a JBL amp when he saw the external amp. I've never heard of anyone recommending to keep the factory unit.
EXACTLY?? now I have my driver door speaker going out ??? is it the amp or the speaker??? AAARRRRGGGHHHH!!!!!! jj
identifying the problem is fairly easy, but unfortunately, you have to take the door panels off to do it. take two of the door panels off and swap the speakers. If the problem switches to the new door, it is the speaker. If it stays at the driver door, then check the connections from the door to the HU. If the connections are solid, then it is probably the amp.
hope this helps.
Now I have another question. Looking through the crutchfield website and Canada's own Future Shop site, I've come across a dilemma. I know some people recommend the Infinity Kappas because the range is better than most subs I've seen thus far. Is that such a large issue? What I mean is, does the range truly matter? I've seen subs start at 18 hz to 150 hz (infinity) and others at 25hz to 500hz (Kenwood). Will the subs that start lower have more punch or the other way around?
Thanks for the guidance, as I will be buying 2 12's sometime this weekend.
885 fogs
& stereo stuff
Extended frequency range is fairly unimportant 99% of the time. Most subs are crossed over at under 100 hz. The exception to the rule would be the use of 8" in the front of the car. In this case, you could cross over the sub higher because localization when in the front of the car is not a bad thing. Crossing over a rear mounted sub higher than 100 hz will make the sub sound like it's coming from the rear.
Thanks ... will be installing a B&M Shifter in a couple of weeks, may as well pull the door panels out while I am in there destroying my interior .. might just try a couple of new speakers .... thanks again .. jj
E
E
good deal on 15 inch fosgates
97 gsxr lotsa good stuff 4 sale
95 talon tsi awd turbo loaded sold
95 se 2.5 mtx loaded (fragile handle with care)2 motors 3 trannies
custom y with hi flo cat,custom dynomax exhaust,upper cat mod
superchip,udp,bat\kkm,proflow maf,ford 9mm wires,svt throttle body,svt intake manifold ,custom kevlar clutch,16 pd. flywheel,svt motor mounts ,svt gauges,eibachs\h&r,omp strut brace,dark chrome 16" rials with 225/50 dunlops,cwazy amounts of audio
Page 2 of 2 1 2
Moderated by  dnewma04_dup1
