CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by Kremithefrog: You still haven't answered my question to WHY IS A COMPRESSION TESTER NEEDED?
Also all you need to be is a tooth off for your car to run like crap.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 648 |
its about time for me to change MY timing belt and I was just wondering...ZXtuners has a timing belt made by eslinger...would that work with the stock cams or would it only work with aftermarket cams? Any info would help. the car has about 80K on it now and the timing belt is "walking" on me and hitting something causing it to get cut up on the edge.
PRIME-TOUR
You're fired! I write the books here!
~Tom~
Posts: 21,653 |
Do you have a link? I can't find it on their site. I don't think it would help you any more than a stock timing belt.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 42 |
I'd be more inclined to determine why it's walking rather than put a different manufacturer's belt in there. Is something not in alignment? Maybe a pulley has some wobble to it?
Posts: 21,653 |
With 80k miles, the timing belt can just wear out enough to do that. Though definitely could be a pulley. I'd go ahead and replace the belt, tensioner, and idler pulleys.
98.5 SVT
Posts: 648 |
thanks guys. yeah when i did the search i pulled this original thread and saw that its a good idea to replace those pulleys. Oh also I read some more on the zxtuner site and the belt works with the eslinger cams only, because it is smaller than stock.
thanks guys
PRIME-TOUR
~Tom~
Posts: 21,653 |
You sure you're not talking about the serpetine belt (which is not made by esslinger and is almost gauranteed to be the wrong size if ordered through zxtuner) for use with the esslinger under drive pulley? AFAIK, timing belt size shouldn't change.
98.5 SVT
Posts: 648 |
nevermind kermit...im stupid and forgot how to read. it clearly says that its a serpentine belt. thanks again guys
PRIME-TOUR
~Tom~
Posts: 2,483 |
Originally posted by LoCoZ: Originally posted by Kremithefrog: You still haven't answered my question to WHY IS A COMPRESSION TESTER NEEDED?
Because if there is one thing I have learned when modding and maintaining a car...is to do things right the first time....don't take unecessary risks....or you may pay later for doing things half ass now.
I used a compression tester when I put on my adjustable cam gears. I checked compression before and after, and guess what, it increased.
Frank McCoy aka Mod-deth aka Mid Life Crisis aka SVT Doood aka mcgainer is a SCAM ARTIST
Pre98 Zetec - Some Mods
Posts: 21,653 |
So the compression increased? But as long as it increases across all the chambers, then it doesn't matter right? So if you do your timing belt install correctly, then you don't HAVE to check compression, right?
98.5 SVT
