Page 2 of 5 1 2 3 4 5
#718591 08/17/03 03:04 AM
W
W
Originally posted by thefairwaymob:
Last week I called Ford Canada and asked what the recommended interval was (nothing is listed in the manual), they said anywhere from 120km to 196km, so I spoke with my service rep - he stated 125km to 140km max. I had my timing belt and water pump and pullies replaced at 125km, at a cost of $600. Both the pump and belt were in phenomenal shape, pullies seemed okay too, looked like they could have lasted another 100km, and now I feel like I was ripped.
Na....you just did Preventative Mantainence. It's such a drag replacing something that you can't feel/see a diffence after its done.....argh.
Just drive your car smuggly , knowing your belt won't cause trouble for a long , long time.
2012 Lotus Evora --------- 95 Mystique MTX - GONE 395,000 Kms --------- Both Zetecs '97 Contour Mtx - stock - GONE
#718592 08/18/03 05:48 PM
if you feel capable of doing this yourself it is reasonable to change everything in about 4 to 5 hours.
you need to support the engine and remove the motor mount, mark or lock the cams and the crank to make sure you don't lose timing, take the three covers off and then replace what you want to
#718593 08/19/03 12:51 AM
it was a easy on my 96 tour i just went to home depot and bought some 3\16 flat bar and cut it down to size (found out i could of bought one from the mac truck for $10)
then i went and bought the new tensioner and spring a new water pump a new T belt and a serp belt and tensioner \\then i put it together in 3hours
its kinda weird with the whole spring deal (i didnt buy the bolt i just use one of my valve cover bolts )
you just install the bolt in the whole under the exgaust cam then install the spring and tensioner pulley at the same time. then you just pull the tensioner over to extend the spring then tighten the bolt , then you make sure the belt is tight on the exgaust cam and crank sproket NO SLACK
then pull the belt over the intake side NO SLACK between the cams then you loosen the tensioner bolt and rotate the motor around twice then tighten the bolt for the tensioner and remove your valve cover bolt and spring
oops dont forget your water pump when your down there
also i had a hard time with the lower rad hoes on the water pump
hope this helps
96 Contour Gl (wifes new car 91 GVR4#1382 (the true sleeper 91 TSI AWD (project celluite AWD & 4WS what else do you want in a car
#718594 08/19/03 07:52 AM
CEG road warrior
CEG road warrior
You need a compression tester and something to lock the cams.
#718595 08/19/03 08:21 PM
You do not need a compression tester.
#718596 08/20/03 06:21 AM
CEG road warrior
CEG road warrior
If you want to do it right you need a compression tester. Better safe than sorry.
#718597 08/20/03 12:21 PM
when I went to replace the belt on my car the tensioner pully was almost completely cracked in half, belt was fine and looked almost new.
Make sure you get all the pullies changed
I'll second that. Changed my belt without changing the pulleys, Let's just say it was a $450.00 lesson learned when I got stuck on the way to a meet.
www.ChicagoCEG.com 2006 White Grand Prix
#718598 08/20/03 04:46 PM
CEG road warrior
CEG road warrior
#718599 08/20/03 08:19 PM
Why do you need a compression tester to change the timing belt?
#718600 08/20/03 09:34 PM
I have no idea why u would need a compression tester for it either.
I will be doing mine this weekend, new belt, idlers, tensioner, water pump, 180 thermo, fuel filter, and serpentine Drive belt. I'm just waiting for my tensioner spring and bolt from the dealer, and mintex rear shoes from bat.
Alan 93 Acura Integra LS 5spd Horizon Gray Metallic ------------------------- -96 Gl Zetec ATX- Totaled as of 11/29/03 at 4pm Champagne Metallic CC Pics
