Okay here we go! I have no clue whats wrong so i need some help... I drive my car just regular and every like 20 mins or longer it cuts off and im like what the %@#! and i try to start it but it wont start so i have to turn the key off completely and turn it back over to start and it will start. and then later on the motor will die again. it will jerk when it dies. so if you know anything how to fix this problem help me out.. cause my car is dieing on me! it has 107K...
We need to know more about your car. A simple code scan will help find your problem. Most intermittent conditions are captured by the PCM.
Jeff
have you fixed your ford lately?
H
H
check that gay plastic thing that all of the wires go to on the battary ,make sure it did not ark or melt the plastic .(i cant spell well)..or better yet replace the plastic thing with copper...i had to do that to the starter too..i too me 3 mounts to find that prblem
98 SVT, clutch masters flywheel, spec stage2 clutch, quaife ,y pipe. and only MOBIL-1 oil. gansta a$$ 2000 Honda Civic on dope("nnnaaawwwzz"). ricers suck KING OF ROAD RAGE i need a center console and cup holder!!!!!1
it might be a cooling problem? is the car just driving along, or is it when u sit for awhile? i might have had the same problem as u, but i would need to know more
