for stock shifter, there are 2 ways you can do it. easiest way is to pull up the shift boot, and remove the torx screw at the right rear corner of the shift tower, the one going thru the slanted piece. remove the slanted piece, and put the screw back in, done.
Other way is to remove the sleeve over the shift lever, a little more complicated, but will give your shifter a different look. To remove this, unscrew the shifter knob, cut the cable tie holding the top of the boot in place, pull up on the sleeve, replace cable tie, done.
