#712213 08/04/03 10:34 PM
is it possible to hook one of those keyless starters up in a manuel car? yes? no? maybe so?
thanks
*I'd rather be a smart ass than a dumbass www.fast4doors.com
#712214 08/04/03 10:39 PM
Yes,
but you have to bypass/disable the clutch switch.
Frank McCoy aka Mod-deth aka Mid Life Crisis aka SVT Doood aka mcgainer is a SCAM ARTIST Pre98 Zetec - Some Mods
#712215 08/04/03 11:31 PM
1
1
Yes it is. I previously had at JTI J4 starter but I switched to a Clifford Solaris. It works great.
Silver Frost 2000 SVT #1443 of 2150 http://photos.yahoo.com/hpick1
#712216 08/04/03 11:55 PM
thanks
It is possible. Bypass the clutch switch. Here is the how to that is included on this Forum.
Originally posted by How To's:
The way it works is the clutch switch provides a ground for the starter relay, located in the engine fuze box. What I did was find this wire and splice in another wire that I connected to a ground. First find the C-100 connector, Its the huge one just aft of the air box, before the strut mount. It is held together by a captive bolt at the engine end. Unscrew this bolt and the connector comes apart. Its actually two connectors in series but the engine side is the one you want. Find the Black wire with a yellow tracer in socket number 31 on the connector. Its a small wire and this is the one you want. I removed the end cap for access, spliced in another small wire, soldered it and insulated it. I routed the other end to the vicinity of the cruise control mount, installed an appropriate lug and tied it down. Reassemble/mate the connector and secure via the bolt. Its either a 10 or 8mm hex. If you prefer you can work on the other side of the C-100 connector BUT the wire changes to a black/green wire exiting socket 31.
Just follow this procedure, install the remote starter and you should be good to go.
-Bishop
*Invisible Hero* 1999 SVT Contour/Amazon Green Keep It Real. Beware the fury of the silent man.
#712217 08/05/03 01:15 AM
Easier way;
Look towards the top of the clutch pedal on the firewall side,
There is a connector with two wires coming out of it.
Either;
1) Disconnect connector from pedal and jumper the two sides of the connector together by inserting a piece of wire or paper clip then tape it up.
2) Cut the two wires and solder them together or use some other electrical connector.
Quick & Easy!
#712218 08/05/03 01:15 AM
If you want to do it the right way, get one specifically
made for manual cars. The one I've read about (sorry, forgot
type/brand) continues to idle the car as you pull the key
and exit the car and stops it after several seconds, so you
cannot forget it in gear.
Tiv
#712219 08/05/03 01:38 AM
Originally posted by SleeperZ:
Easier way;
Either;
Quick & Easy!
That to. The How-To is all I knew of. Good post.
-Bishop
#712220 08/05/03 03:21 AM
Q
Q
very possible i have the viper v790 2way remote start on my 5spd... DEI makes a clutch safety switch you can purchase ... so if you leave it in gear it won't take off, i NEVER leave my car in gear so i don't really worry about that.. but also look into Compustar, they make an alarm for mtx cars
#3162 of 6535 98 SVT Silver frost Viper Responder 791 w/ 2way remote start Let the modding begin!
#712221 08/05/03 03:21 AM
Q
Q
very possible i have the viper v790 2way remote start on my 5spd... DEI makes a clutch safety switch you can purchase ... so if you leave it in gear it won't take off, i NEVER leave my car in gear so i don't really worry about that.. but also look into Compustar, they make an alarm w/ remote start for mtx cars
#712222 08/05/03 10:09 PM
H
H
quickse, your viper alarm allows for safe mtx starting? that dei clutch thing is for that purpose? i've never heard of that.
i have a clifford ag4, amazing.
