#71046 12/05/00 07:41 PM
E
E
Not sure what it's called but it starts at kick panel and runs to end of driver door, then new one for rear. I am trying to run RCA's under there Do you just remove two clips and the three screws? If so what do you use to get the srews out, I don't have a screwdiriver that will get them out. remember this is the plastic piece under weather striping.
Thanks
-Jon
98.5 E1 SVT Silver Frost
New->KKM!
15.5 1/4
I also had the hardest time getting those kickpanels off. So what i did was unscrew the screws and shove it under with my fingers. Remember it is best to have your power cable away from your RCA's because it may pick up distortion. I have 2 amps and ran power cables and ant cables on the driver side and RCA's and speaker wires on the passenger. If you have any questions installing, i have done it.
I think I know what you are talking about except that the piece that makes up your kickpanels is one long piece that runs all the way back to the rear seat. That might be why you are having trouble. I seem to remember when I installed my stereo we had to remove the seats to make everything easier. Those panels are a b$@#h to get off. They probably come off without removing the seat but we were taking those out anyway and it made everything much easier to work on. HTH.
Brad W.
1998 Silver Frost SE
brantleyiii@earthlink.net
photos.yahoo.com/brantleyiii
"Good leaders are scarce, so I'm following myself."
Moderated by  dnewma04_dup1
