Posts: 3,076 |
Originally posted by ZetecRacing: besides what's SOOOO special about a SVT contour.... NOTHING.
I forget, what does the "S" in "SVT" stand for again? Talk about a oxymoron! ROFLMAO!!
2000 SVT Black/Tan #1633/2150 (a few mods)
Alpine: CDA-9835, MRV-F540, MRD-M550
PG: TANTRUM-X 6.5 COMP all around.
Some people wear Superman pajamas. Superman wears Chuck Norris pajamas.
CEL currently: Off
Posts: 803 |
amazing how my thread turned duretec Vs. Zetec thread. all i asked for was a simple average 1/4 mile time that a MTX zx2 w/exhaust would run.
FORSALE - 17" FSVT Wheels, TRubendz catback w/magnaflow muffler PM ME
02 celica GT-S 6-spd w/ TRD bodykit
Greddy evoII exhaust, DC sports header
Injen Short ram intake, TWM short throw shifter, 18"centerline storm wheels, Tein basic coilovers
Posts: 163 |
Originally posted by MSquared: mb an automatic V6 contour...
not my V6 ATX. I beat a ZX2 and a Suzuki Areo (150HP) by 2.5 car lengths--powershifted!
a D*CK SLAP IN THE FACE IS ALL I GET FOR STICKING MY NECK OUT FOR A FORD... PLEASE DELETE MY ACCOUNT!
Posts: 2,517 |
Thought this was interesting. I happened to be filling up the car at a local Sunoco when on the other side of the pump was a zx2 s/r. Sooo, I decided to ask him some questions about what they come with stock and ended up talking about his times he gets at Englishtown on Sunday night import vs domestics. 15.8 STOCK 15.5 ADJUSTABLE CAM GEAR 15.3 EXHAUST 15.1 ESSLINGER CAMS ??.? HEAD WORK (hasn't run yet) Not only that but he's looking at a stronger tranny via the Escape with 4.56 gears v/s the stock 4.10's. I told him straight up what I had on the 'tour (hybrid 3.0L) and said I'd have to break out the Cobra to beat him. I don't think my Contour could hang with his mods and experience.
Just FYI.
Posts: 74 |
Were you the guy in the Yellow Mustang Cobra? If its the Sunoco on Freemansburg Ave outside of Easton, PA then I'm the S/R owner.
Just FYI.
Well you got that pretty close. Good memory
1/4 mile times on my Cali emissions 2000 ZX2 S/R. 15.8 stock with 1400 miles on the odometer. 15.3's with a shorty header and AF/X underdrive pulley 15.1's@90 MPH with adjustable cam gears, a shorty header, and AF/X underdrive pulley 15.1's@97 MPH with a 2.7 60' time with a Howell Automotive/Darrel Cox ported head with big valves, Esslinger cams, a shorty header and AF/X underdrive pulley. I have absolutely no traction at the track now, even with drag radials. I just sit there and spin through 1st and part of 2nd gear even when I launch at 2500-2700 RPM. I'm going to need slicks and a stronger diff to put the power to the ground during the launch. Also, the 4.56 gears will help my 1/4 mile times becuase 4th and 5th are both overdrive gears in the ZX2 and the car doesn't pull as well as it could in 4th during the last couple hundred feet of the 1/4.
A ZX2 owner in Cali. with basicaly the same mods I have and a 2.5" cat back exhaust is running 13.9's to 14.2's on slicks. I still have the 1-7/8" crush bent stock S/R exhaust on my car.
From a 60 MPH roll my ZX2 pulls pretty well. On a trip back form Harry's in Allentown with a trunkload of parts to fix my neon, I was able to pull on a friend's stock 5 speed WRX from a 60 MPH roll. At 110 MPH I had a few car lengths on him.
The info given before on the S/R was mostly correct: 2000 ZX2 S/R Only 2000 produced - 1,000 in Zinc Yellow, 500 in Red, 500 in Black. Iceman intake Leather shift boot B&M Short throw shifter Centerforce Performance Clutch Visteon PCM with no speed limiter and tuned for 91+ octane Tokico Struts Eibach Pro Kit Spring Energy Suspension Bushings Energy Suspension Engine moutn inserts Borla exhaust - just a muffler on stock pipes. S/R wheels 205/55ZR15 Goodyear Eagle F1 Steel tires Rear disc brakes Silver gauge surround 150 MPH/240 KPH speedometer Ford Racing Blue valve cover S/R badges and stickers 143 HP@5750 RPM 146 lb-ft of torque@4500 RPM for the Cali emissions models. 146 HP@5750 RPM 150 lb-ft of torque@4500 RPM for the 49 state emissions models.
On a side note, I had a 1998 5 speed ZX2 that was 49 state emissions, not Cali emissions. It ran a 15.8@88.4 MPH bone stock at Island Dragway in NJ on a 80 degree day with ~75% humidity. The fastest I've witnessed a stock regular model 5 speed ZX2 run the 1/4 was a 15.6 and the fastest stock non Clai emissions S/R ran a 15.4 in the 1/4.
I am Canuckian
I am Canuckian
Posts: 4,168 |
And that is what I was talking about back towards the begining of the post. The mighty little zetec can do great things, especially in a lighter car.
Green 96 mystique gs 4cyl mtx
16.9 in the 1/4 mile @102500 miles
95SE in Midnight Red MTX
MSDS headers and y-pipe
SVT exhaust
SVT UIM
Optimized se TB.
Full pre 98 SVT body kit
15.741 @ 87.73mph :)
Posts: 1,049 |
back when i had my mr2 this guy i worked with had a zx2 and i use to smoek him all the time. and i know my tour is faster than my mr2.
Posts: 2,517 |
Yep, that was me. Thanks for the memory comment!
