Page 1 of 6 1 2 3 4 5 6
#708582 07/31/03 06:02 PM
I was planning on doing the tranny cocktail, but someone in the car repair business told me that I should not. He told me that since the fluid has probably never been changed that changing it now (72,000mi) may cause the gears to "slip" or damage or something like that. Will damage or "slippage" occur if I still decide to change the fluid?
Thanks
#708583 07/31/03 06:14 PM
Thanks
That person in the car business is referring to Automatic transmissions where they have bands in them. If you don't properly maintain an auto tranny, then it's best to let the fluid sludge up and keep it in there till it blows.
1998 T-Red SVT #957 Born 5/14/1997
#708584 07/31/03 06:24 PM
I second this, it will do only good if you change the fluid.
I've changed mines somewhere between 60k and 70k for the
first time, and it definitely helped a lot.
T.
#708585 07/31/03 10:52 PM
I've changed mine 3 times in 3 years. (1k, 16k, 31k)
Transmission shifts like a top even when banging gears above 7500 rpm.
I'd recommend using Redline MTL.
#708586 08/01/03 01:27 PM
Thanks for the responses everyone, I will go ahead and get this done.
#708587 08/01/03 07:22 PM
I second the Redline MTL. Demon told me about it a few months ago...and i must say, it shifts better on cold starts and even better when its warm than the cocktail.
Roz
#708588 08/01/03 08:19 PM
One last thing, now I hear when you're getting a little grinding its best not to switch to the cocktail. What's the best fluid combination to use (swap in)when I want a smooth shifter and when a small grind is occuring infrequently? i.e. Reg ATF + F.Modifier, Synthetic only, etc...
Thanks
#708589 08/01/03 08:31 PM
If you want to use a dino fluid then get some ATF+3
Just remember to change it every year.
Also if your fluid is old it could be causing the grinding. (lack of syncro oiling for example)
I would try the Redline MTL.
#708590 08/01/03 09:52 PM
What mixture though, all Redline MTL? Or half and half? Or a little MTL and more ATF +3?
#708591 08/02/03 01:40 AM
If you are going to use the Redline use it 100%.
Mixing synthetic oil with dino oil is simply wasting money.
