Posts: 1 |
Hi - I'm trying to start playing with my computer - the EEC-V is not transparent like my mustangs (93 and 66 - both jacobs ign, mallory computer). I see diablo and superchips and alpen out there, but I'm looking to do some of it through a laptop to the 104 pin connector live - I know the flash is accessable, just need some how to for this thing. I design ASICs and embedded systems for a living, so I should be able to do this - anyone else got any suggestions - car is my daily driver - 97SE, 5sp, KKM intake, Borla exhaust, SVT springs and struts, baer brakes, 55hp Zex nitrous, 17" wheels and Nitto's. Might put on an SVT intake manifold and injectors, but I'd like to look at varying the injector pulse and ignition timing too. Any help out there?
Andrew
Posts: 1,860 |
It's not building it that is hard, it's getting the software to communicate that will be largest obsticle.
2001 Lincoln LS8
1994 Lexus GS300
Posts: 299 |
You probably need the spec sheets on EEC-V. Is that publically available information? A terse search on Google didn't provide much.
I thought about making my own interface for my 6 for OBDII (CAN protocol, specs available) but I emailed Alex Pepper and he said he'll have it in 6 months tops so I'm not going to bother.
But good luck to you man!
Posts: 9,602 |
I wish you lots of luck and hope you have months of spare time to kill. (No to mention in you are going by just guessing a few PCMs and engines probably)
Not only does each PCM have a different code, but then there are processor strategies, and numerous actual board revisions to work through.
Some versions don't even allow for easy downloading.
I would email the folks at TwEECer and ask them if they have had any luck with your year, PCM style, and processor. That should at least give you an idea of what is in store for you!!!
...and yes... EEC-IV is NOTHING like EEC-V. EEC-IV is simple child's play...
2000 SVT #674
13.47 @ 102 - All Motor!
wannabe-CEG'er
wannabe-CEG'er
Posts: 32 |
I'd contact Mike Grover first, but last I heard the Contour's PCMs are supported by the TwEECer. ECC-V support is 90% implimented, and should be 100% supported by the time the final v1.20 of the software is available.
Just an attack, not an observation....
04 House
04 Gixxer 600
Posts: 284 |
HAHAHA, $550? The couple tenths youd pick up arent worth it. Besides, I saw another kit on this forum that does the same thing for $120.
Webmaster
Webmaster
Posts: 1,359 |
Originally posted by tbirdjayc: HAHAHA, $550? The couple tenths youd pick up arent worth it. Besides, I saw another kit on this forum that does the same thing for $120.
You may have seen a SCANNER for $120, but not a kit that can change any parameter in the PCM on the fly....
Tweecer is the bomb (if your PCM is supported).
-Lance
Lance Kinley
CEG Webmaster
95 SE, "Cassandra"
10 years!
wannabe-CEG'er
wannabe-CEG'er
Posts: 32 |
There is no product on the market that does everything the TwEECer allows you to do for Ford ECC at any cost. Comparing it to most "other" ECC tuning products is like comparing an 18 piece socket set from Wallmart to a 500 piece Snap-On tool set.
04 House
04 Gixxer 600
Posts: 9,602 |
What an ignorant fool...
Almost not even worth the reply... Almost...
2000 SVT #674
