Page 2 of 6 1 2 3 4 5 6
so u r saying I should buy one from a jukyard ??
And they could work around it ?? (placing the turbo)
Is that it ???
Anything is POSSIBLE... sowing the seeds of love"
Originally posted by LoCoZ2:
Plus it is nice and short, where the cat sits is where you could mount the turbo, and just relocate the cat (as you can see I have been planning).
where to ??? on the horizontal pipe ??
Looking at these posts, what an idea. If this could work, you could start a lot of turbo tours. Just think . All the power to you!
1992 Ford Escort LX-E -Tracer LTS spoiler -GT Grille
1
Does this "kit" come with all the lines for the oil and coolant?
Nick Johnson 87' & 88' Thunderbird TC 96' Contour SE Midnight Red ATX
I guess it does. I am not sure. These are the kind of things I need to know so that I can ask them.
Even if it doesn't come with oil lines you can get them made cheap, just go to napa and use hydrolic hose and get custom fittings and it can be done cheap.
If the Cougar and Contour Zetecs are the same then you can't use the stock manifold cause it puts the turbo too close to the AC compressor and your downpipe will hit it, and you won't be able to give it a good bend to clear it. You need a manifold that mounts the turbo around the 3 and 4th cylinder so you have enough room to put the downpipe. I have a 3" downpipe and a turbo mounted right around the 3rd cylinder on a log manifold and I have barely a millimeter of clearance between the pipe and the bolts on the AC compressor.
Doing a do-it-yourself turbo is cheap if you can do the work yourself, the most expensive thing is fuel managment. What year Tour do you have? If you have a return fuel system it will make it easier since you can use a little fuel pressure trickery to swap bigger injectors to get the A/F ratio right.
You still have to deal with timing. Timing has to be low under boost, and as I have recently found out you can't pull too much timing. Pull a lot of timing in the midrange then add alittle back in the upper RPMs to cool the EGTs. Boost and EGT guage are MUST HAVS, forget Air/Fuel, spend the extra cash and get EGT.
This link will give you an idea of what's needed:
http://www.axs4u.net/home/louiem/
2000 Rio Red I4 Cougar 200whp & 210wtq at 9psi 254whp & 276wtq with NX 35shot WRX TD04 Turbo, Cut Short Shifter, Strut Tower Bar, 17" ZN Wheels, Roush Springs, Starion Intercooler, NX 35 shot, HKS SS BOV, Full 3" exhaust,StreetFlight Chip
that's why you remove the a/c compressor. cougar zetecs have vct right?
Yeah I got VCT. Was removing the AC compressor line a joke? Maybe where you live it's mild enough to not need AC, we're not all that lucky. Also the stock manifold just looks ugly. You're better off looking at a stock Focus manifold or one of those shorty headers could work also.
South georgia isn't exactly mild. Not a joke either. Maybe it's not for everyone, but I don't sit in my car too much without it moving, and when it's moving, there's plenty of air flow to keep me cool. Defrost isn't great anymore, but it's ok for south georgia.
Moderated by  Loco4G63
