My car has just started losing fluid and getting hot. If I turn on the AC and drive down the road,it stays at M. I have to fill it back up everyday. Is it the water pump and how hard is it to change?
my brother and i just changed the water pump on my 96....
he did most of the work, and he said it's fairly easy, but expect to spend all day on it (he's very experienced and we had it done in 3-4 hours). you have to jack up the engine and remove the upper engine mount, which on my car required a impact to get it loose. then you have to remove the serpentine and the water pump pulley, then take off all the plastic covers. then you remove the water pump. install is reverse of removal....
this is just a vauge guide, you might need air tools. also while you are in there, if the timing belt hasn't been changed in a while, you might want to buy a timing belt kit (NOT JUST THE TIMING BELT, get the pullies/tensioner with it.... $175 at o'reilly's) and replace the serpentine as well.
Goin' Round Traffic Circles @ 50Km/h!!! \m/ -- 1998 E0 SVT #2119 of 6535 \m/ -- 2003 Sentra SE-R Spec V
Welcome to CEG!
Check to make sure the fan comes on with A/C off.
Check fan fuse or fan relay.
Thanks for the info, I already changed the timing pulleys a month ago. I guess I should have changed the water pump then.
Is it leaking near water pump, or somewhere else? Could easily be the pump, but you never know!
