Page 2 of 2 1 2
When I bought my car, I had intended to replace the stock unit & speakers anyway. They're OK, but that's it - just OK.
As fate would have it, the drivers front speaker would cut out on my 1999 SE also. It turned out to be the head unit had some fried components - I suggest you may be needing a new unit too.
You should do some research before you buy a "cheap" unit. Look for some THD (Total Harmonic Distortion) numbers - lower is better and there is no substitute for quality sound. JVC seems to make some really nice sounding CD players that can be had in the $120 to $250 range. They put out 45 watts per channel or more - Not bad. I have also found that the tuners in the JVC units are pretty darn good as well.
For a simple install, Best Buy will install for free around here, or you can just purchase a JVC to Ford adaptor & plug it in to your existing harness plugs - EASY. That way you can re-install your factory stereo if you ever trade in the car.
A little more than $0.02 worth.
Awwright guys, thanks for the info. I guess the next step is to swap the two front speakers and figure out if it's the speakers fault.
Thanks again.
-Kurt 50% of all people are below average.
Sounds like yet another common prob w/ the tours. My csvt is doing the same thing. I'll just be drivin down the road listening to a cd and you can hear the sound fade from speaker to speaker. I think it's done it a few times while I'm just listenin to the radio too. I'm glad I took my Pioneer out of my Neon, cuz the way it looks I'll probably need it soon. Hopefully you figure out what's wrong!!!!
~*~Bonnie~*~ Amazon Green 00 SVT Contour, #? of 2150, born 2/00 (bought 7-16-03)
Page 2 of 2 1 2
