It should run low 16s stock that doesn't mean anyone behind the wheel will run 16s. I am impressed that you beat a 2700lbs car that has 145hp/160lbs and the advantage of rear wheel drive, I guess the person you raced can't drive the car. I still can't believe it when i watch my friend letting his car loose taking off at 5000RPM, these car can go off the line. He always gets a car length on me off the line but once i'm in second gear its all over 'he starts falling to the duratec', and by the end of third I'll have 2 cars on him.
95 SE MTX
DH UIM, 65mm TB, SC CAI, Quaife, Centerforce, Fidanza, UR Pulley, F/R Strut Braces, Cross Drilled Rotors, S.S. Brake Hoses, 18" Enkei RS5, SVT Engine Mounts+Inserts, MSDS & y-pipe, Trubendz resonated exhaust & MagnaFlow cat
