Many people have asked and nobody as ever posted the answer.
So since I needed to do it today,
I thought I would do a little write-up.
Hope it helps somebody.
1) Find the two coolant hoses that run to the firewall. They are located under the car. They are almost directly across from the oil drain plug. Here is a pic to identify them.
2) Follow the driver's side line (right side in pic above) back about a foot and you'll find a spot in the hose where two hose clamps are about 1" apart, you will be under the EGR passage mating up to the intake manifold (sorry no pic). The hose is actually cut here and and each end of the hose is clamped on to a piece of metal pipe (pictured below).
3) Install the flush "Tee" in place of the metal pipe (pic below).
In the above pic you can see the EGR line that is attached to the intake manifold (just below and to the left of the "Tee").
