Page 2 of 2 1 2
there has been a few times that i have turned the car off with the wipers on and when i got to start it up it wouldnt crack till i let the wiper go back down before i start it. or somethign liek that. i think it was pats related i have a 98 se 5 speed and the clutch was pressed when i went to start it.
98 contour s.e. sport mtx http://www.cardomain.com/memberpage/503352 all mods shown on page
OK
Finally I discovered the problem and easy fix
The Second terminal on the bettery Positive post was loose [not the battery terminal]and had overheated and melted the plastic into the contact area causing an insulation effect !!!! What a mess
I filed the melted plastic away and made metal to metal contact with a tightened the terminal
WOW 500 miles without a hesitation !!!!! I Went to Maine this week and back
CLEAN AND TIGHTEN YOUR TERMINALS !!!!
Problem solved with no dealer involved !!!!
1999 GREEN Contour SE SPORT Duratec V6, ATX, SUNROOF, 93,000 Miles, P0420 ON&OFF -replaced DS O2 --did not FIX *New TORQUE CONVERTER @ 53,000-Intermittent P1744 *New DASH at 53,000 and New DASH lifted-now using MOLLEY bolts to pull down
Originally posted by contoured:
OK
agreed...I ahd the same problem...I needed to get a new battery though....the batteery acid was coroding my wires......Always check you terminaks first.
Roz
Page 2 of 2 1 2
