#70322 10/25/00 01:41 PM
I'm replacing my HU as the first step in completely rewiring the entire stereo. Still (temporarily) going to use the factory speakers, but would like to bypass that piece of aluminum Ford calls an amp, still using factory wiring. Anyone have a good wiring schematic so that I can aviod 4 hours of testing?
98.5 Tour SE Sport ATX
No Mods ... that I know of ... yet!!
98.5 Tour SE Sport 2.5 ATX
Mobile 1 / Purolator
Bosch Wiper Blade/Arms
60W low /100 W high beam
Clarion DB315 HU
Blaupunkt ODx663 Front and Rear(in progress)
Sony 4045 Amp
"New" cupholders
#70323 10/25/00 02:58 PM
Anonymous
Unregistered
Anonymous
Unregistered
Why don't you just get the harness adapter? Crutchfield makes one, and I know there are other sources. It plugs into the wiring at the amp, and should be long enough to reach the trunk, or wherever you mount your amp! This way you can always return everything to stock(i.e. not cut wires)
1999 SE V6 MTX
Borla Cat-Back(welded on w/clipped Cat)
Enkei RS6 wheels/Yokohama AVID H4 rubber
Clarion CD head unit
Clarion 6CD changer under passenger seat
MTX 10" subs in sealed enclosure
2 MTX Thunder amps (1 200x2, 1 100x4)
Cerwin Vega 5x7 plate 3ways
ASC Power Moonroof (like the controls better than factory)
Medium Steel Blue Metallic exterior
Moonlight Blue Cloth interior
Limo Tint rear 3 windows
35% tint front doors
KKM True-Rev
Energy Suspension bushings/inserts(on order)
2000+ cupholder insert
TH Fix
Fog Light Fix
#70324 10/25/00 04:51 PM
I'm not installing my amp until after I replace the speakers. Not really planning on returning it to stock any time soon. I want to by-pass the ford amp, using the one in the HU until I install my amp and replace speakers. Can anyone explain exactly where the Crutchfield adapter plugs in, and if it B/P's the ford amp? Also price for the harness?
Clarion DB315 HU
Sony 4045 Amp
"New" cupholders
#70325 10/25/00 05:42 PM
Anonymous
Unregistered
Anonymous
Unregistered
I bypasses the amp completely! I comes with very long wires. I originally used mine to do what you want to do(go to HU). I just bundled up the excess wire! I now have the harness running into an external amp in the trunk. I really can't remember what the cost was, but I know it was under $20! You can call Crutchfied at 888-955-6000.
Moderated by  dnewma04_dup1
