Posts: 94 |
My speedometer and odometer stopped working on the freeway! I was going about 80-85 and all of the sudden the needle dropped! I tried restarting, no luck! I then realized that the odometer wasn't turning either! What the hell do i do?
~Weasel Bomb
1998 Contour SE Sport
TOTALLED
For Sale:
DUAL EH'D Powdercoated Blue UIM (prefer local pickup)
Bullitt Fuel Door
Posts: 1,785 |
Damn, my only thing I can think of is check the fuses. Never had that happen.
Just a Plain SE.
AKA Big Country
I maybe path914's B**** now, but wait until he needs his clutch done. We will see WHO is WHO's B**** then!
Posts: 2,440 |
drive around with no odometer and keeo the miles low for a while. if you get pulled over for speeding tell the officer that it just happened and you were on the way home or to the garage to have it looked at.
"What did you think about that Dorothy girl?"
"The whole Judy Garland thing kinda turned me on. That doesn't make me some sort of fag does it?
"Nah baby, your money."
98 Black SVT #3560 of 6535
Posts: 3,632 |
When I had my Contour I had to have a speedo problem fixed under warranty.
The speedo, tach would cut off after I hit a big bump and come back on after another.
I will check to see what the write up says later.
"Cobb - It's not just for corn anymore!"
Posts: 717 |
don't know about contours, but I had an Isuzu Trouper that threw a CEL when the speedo cable broke.
contours, deloreans & fiats, oh my!
Posts: 1,044 |
Only the 95s had mechanical drive speedo cables, so this is an electrical problem of some sort. (Fuse, connector, etc...)
Posts: 94 |
took it to a garage today. and i had a CEL on for awhile in addition to this. they said they need to replace my O2 sensors + a speed sensor and total parts and labor will be $475. i'll be the guy bent over in the garage, just in case you can't find me.
~Weasel Bomb
TOTALLED
For Sale:
Bullitt Fuel Door
Posts: 21,197 |
Change the O2's yourself! It's easy. Well except for the upper rear one. Let them tell you which needs to be replaced and do it yourself. I'll bet it's not the O2's and it's an EGR code though so at least you'll have a wattanty on the O2's.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 2,397 |
That happened to my 'tour with about 20k miles on it. On my way back from cali to nm about 100 miles out my cruise control cut out, speedo and odo stopped working. They had to replace the speed sensor...luckily mine was still under warranty but it took the bastages 5 days to do it while I sat burning up vacation time I didn't have. Oh man bringing back bad bad memories of the first 2 years I owned my car.
Formerly known as Sneaku
I MISS MY BABY!!!
'00 Blk CSVT #1087/2150 built 12/23/99
Posts: 94 |
~Weasel Bomb
TOTALLED
For Sale:
Bullitt Fuel Door
