Posts: 9,602 |
225's fit. No way...
This is a shocking new discovery... drip, drip, drip
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 328 |
Hey smart a$$. As you can see below my name, it says New CEG'R. From what I understood 215's were the fattest you could run, I've never heard otherwise, thus why I made the comment and was curious. So stick it.
1999 CSVT-Black 15.8@89mph
Driver for hire. PM me.
Posts: 328 |
I don't understand the "Drip, drip, drip" part of your sentence. Are you trying to be cute saying you are wacking it or are you just crying? I just don't understand lame mans terms.
Posts: 4,016 |
Don't sweat Demon's antics BURNTU2, he's a smarta$$ to everyone at some point or another. It's how he gets off.
2006 Mazdaspeed6
1997 Yamaha YZF1000R Thunderace
1996 Volvo 850-R
Posts: 2,779 |
hahaha, i flipped out when he first said something to me too, you'll learn that he's actually ok, especially on technicalities....
Posts: 39 |
I'm running the BAT kit with Koni's, RS-5's and 215/45's and I have rubbing issues in the front. I just switched over from H&R's and never had this problem. It's mainly over bigger dips or uneven rolls in the pavement. The BAT's sit just about even with the HR's in the front, maybe a smidge higher. What gives?
Posts: 506 |
225/?? What profile? Thanks.
'98.5 SVT E1
T-Red, Midnight Blue
All stock
Posts: 873 |
Originally posted by SVT 124: I'm running the BAT kit with Koni's, RS-5's and 215/45's and I have rubbing issues in the front. I just switched over from H&R's and never had this problem. It's mainly over bigger dips or uneven rolls in the pavement. The BAT's sit just about even with the HR's in the front, maybe a smidge higher. What gives?
It's called spring rate. From what you just said I would assume that the BAT springs are less stiff then the H&R's, therefore allowing more suspension travel to occur.
2004 Focus PZEV 2.3L - KW sport suspension, SP camber plates, Eibach front swaybar, FS intake, FS Stealth exhaust, 3.82 Final, Torsen ATB, Prothane MM insert, E1 CSVT wheels
1/4 mile - 15.201@89.4mph
Posts: 39 |
That's what I was thinking aswell, but I had the HR's on KYB struts which aren't as good as the Konis for lowering springs.
Posts: 873 |
Originally posted by SVT 124: That's what I was thinking aswell, but I had the HR's on KYB struts which aren't as good as the Konis for lowering springs.
From my experience with Konis and KYB AGX's (obviously not on a contour) is that the Konis a by far softer as far as compression goes. They are about the same in rebound. The KYB's were incredibly harsh in compression. So I'd imagine it could be a combination of both softer springs and shocks that have a higher compression rate.
