Page 2 of 4 1 2 3 4
225's fit. No way...
This is a shocking new discovery... drip, drip, drip
Hey smart a$$. As you can see below my name, it says New CEG'R. From what I understood 215's were the fattest you could run, I've never heard otherwise, thus why I made the comment and was curious. So stick it.
1999 CSVT-Black 15.8@89mph Driver for hire. PM me.
#702567 07/27/03 05:53 AM
I don't understand the "Drip, drip, drip" part of your sentence. Are you trying to be cute saying you are wacking it or are you just crying?
I just don't understand lame mans terms.
#702568 07/27/03 06:03 AM
Don't sweat Demon's antics BURNTU2, he's a smarta$$ to everyone at some point or another. It's how he gets off.
2006 Mazdaspeed6 1997 Yamaha YZF1000R Thunderace 1996 Volvo 850-R
#702569 07/27/03 09:36 AM
hahaha, i flipped out when he first said something to me too, you'll learn that he's actually ok, especially on technicalities....
99 SVTC, T-Red, #652/2760-12.8.1998 Mother#@%@!* did I sound abstract? I hope it sounded more confusin than that!
I'm running the BAT kit with Koni's, RS-5's and 215/45's and I have rubbing issues in the front. I just switched over from H&R's and never had this problem. It's mainly over bigger dips or uneven rolls in the pavement. The BAT's sit just about even with the HR's in the front, maybe a smidge higher. What gives?
99 Silver SVT #1264/2760 SVT124@aol.com
225/??
What profile?
Thanks.
'98.5 SVT E1 T-Red, Midnight Blue All stock
Q
Q
It's called spring rate. From what you just said I would assume that the BAT springs are less stiff then the H&R's, therefore allowing more suspension travel to occur.
2004 Focus PZEV 2.3L - KW sport suspension, SP camber plates, Eibach front swaybar, FS intake, FS Stealth exhaust, 3.82 Final, Torsen ATB, Prothane MM insert, E1 CSVT wheels 1/4 mile - 15.201@89.4mph
That's what I was thinking aswell, but I had the HR's on KYB struts which aren't as good as the Konis for lowering springs.
Q
Q
From my experience with Konis and KYB AGX's (obviously not on a contour) is that the Konis a by far softer as far as compression goes. They are about the same in rebound. The KYB's were incredibly harsh in compression. So I'd imagine it could be a combination of both softer springs and shocks that have a higher compression rate.
Page 2 of 4 1 2 3 4
Moderated by  1314_dup1
