i said i was leaving but im makin money a lil faster then i thought
im gettin two 2ohm DVC subs (i also have the choice of gettin 1ohm speakers) if i wire em parallel wut will be the ohms to the amp
if i wire em in series wut will be the ohms to the amp
now if i did it correctly i got .5 ohm for the parallel and 2 ohms for the series
which amp would be better for each app.
rms power (mmats amps)
600W @ 2.00Ohm
800W @ 0.50Ohm
1200W @ 0.67Ohm
1200W @ 2.00Ohm
if im wrong wit the ohm-age then let me know thanx
-afr0
no sig cuz my %$## is gettin all re-done
Sounds right, but the lower the impedence, the less control the amp has over the speaker. This leads to bass that can be a lot boomier and looser than it should sound.
What brand of speaker is it? Just curious...
Also, if bridge a two channel amp to each sub you can divide the numbers you came up with by two. (.5ohm bridged=.25ohm, 2ohm bridged=1ohm)
98.5 Contour
Zetec w/ auto (doh!!)
modified stock airbox
res and muffler removed
glasspack added
Knauberized
Pioneer CD
Alpine speakers in all doors
2 pioneer 10" subs
-Ken V.
psycho_bass@hotmail.com
My Car
DD 9500 12"'s mmmmmmmmmm power
i dunno if the amps are bridge or wut with the numbers that i posted in my first post but it wouldnt matter cuz those are the numbers that i will be using to do wutever. cant help the low impedences it only comes in 2ohm or 1ohm
-afr0
Your figures are right for the OHMmage on teh amps, parallel and series. One thing I would check though is that in series, the second sub in the string is dependant on the first one. If the coil starts to go in the first, it might accelerate the frying of the other by sending screwed up signals to the OK coil. Also, I'm not sure if this applies here, but have you ever hooked up 2 light bulbs in series? The second one in the circuit is always dimmer. Plus, if one goes, the other will fall silent
Eric B.
Ottawa, ON, Canada
98 Mystique V6 5spd. Toreador Red
Modified Airbox with K&N drop-in, Cool Blue bulbs, Homemade solid brass shifter knob, Sony CDX-L300 head unit
http://photos.yahoo.com/LBuzzer/
i didnt plan on hookin em up in the series cuz i get less power out of the mmats amps cuz they are designed for low impedences like that... just pondering the idea if i use my infinity beta 300 to power them for now.
-afr0
Moderated by  dnewma04_dup1
