#697408 07/19/03 04:54 AM
F
F
Hello,
I am buying my First Contour (1998 Zetec).
The gauge cluster it has now doesn't have a tach, and i was wondering if i were to swap out one that had one, if it would work. I know you can do this with Focus's, but i don't know about contours?
Also, could someone just tell me when the timing belt would be due for replacement?
Thanks a Bunch, and look forward to being a Contour Owner WOOHOO!!
FlaXXMaN - 1998 Contour Zetec MTX 202,000km and counting
#697409 07/19/03 04:08 PM
CEG road warrior
CEG road warrior
You can use a gauge cluster with a tach...just need to find one with a tach from a post 98 Contour.
#697410 07/19/03 06:09 PM
hector is right... however if you get one from say a 99 or a 2000 there is a SMALL possiability that some of the dummy lights will be incorrect.... as in your check engine light could be the over drive off
2003 Subaru WRX some mods Even if you don't have the answer, you certainly have to admire the problem. aka ZetecRacing
