Posts: 3,627 |
ok so I get in my car yesterday and the speedo isnt working at all... everything else works but it doesnt and I have taking the dash apart and made sure the needle was still on tight and that everything was pluged in.... is there like a hidden fuse or something
EDIT: if it helps my Cruise isnt working either
Trollin the boards as of 9/23
Originally posted by GS474: stock hp is never enough
Posts: 2,382 |
Is there a speedo cable? I wonder if it may have broken. Doesn't it connect to the transmission somewhere? I'm really not sure on that........
"Fear is the little death."
Muadib.
Posts: 1,044 |
I think 95s are the only ones with mechanical speedo cables. Probably a loose connector, but maybe a fuse. The speedo will probably have to work for the cruise to work. Possible VSS sensor or connection but thats just a wag.
Posts: 1,459 |
You won't have a cable on a 96. Instead, it will be electronic. Your VSS (vehicle speed sensor) may have died. It is a small plastic device, maybe an inch in diameter, maybe an inch long, with a few small electric wires emerging from it. It is mounted at the back of the transmission, toward the firewall, down low. The VSS sends a signal to the speedometer, and also to the cruise control.
95 Mystique Zetec, MTX
2000 Taurus SEL 3.0L Duratec
1994 Crown Victoria LX 4.6 V8
1993 Chevy Silverado 4.3 V6
Posts: 3,627 |
so is it accessable if I jack up the car and get under it or do I have to do a butt load of work to reach it... how much is said vss sensor and who do I know if that is the problem
Posts: 2 |
Well if u got a 96 zetec auto. then u got two sensors the one by the speedometer and the one by the transmission. If the on by the transmission was not working u would not be able two drive your car. Because it would not change gears on your tranny, would not read miles. I had the one sensor by the tranny come off n was a pain to locate. Had to got to ford n was shown the two sensors.
Posts: 3,627 |
I have a 96 se v6 manual tranny
Posts: 1,459 |
It's accessible if you jack up the car. I won't say it's easily accessible, but then nothing is easily accessible on our cars. You just have to reach through, around, and over a few obstacles, but it can be done without a great deal of trouble. I don't remember the exact cost, but I think I paid $20-30 or so. I believe I have an extra one at home, that you can use to see if that's the problem. If I do have one, you're welcome to it. I'll try to check tonight, if my feeble mind can remember it.
Posts: 433 |
Try disconnecting the battery for awhile and connect back again...I got my car back from the body shop. I drove it off and the speedo didn't work. i disconnected the battery and then hooked it back up and it worked fine. you could also try resetting the ecu.
Click here for Pics.
Andre
'99 SE Sport
Custom body kit
Corbeau Racing Seats
CAI
Eibach Springs
CUSTOM KITS FOR SALE!!!
Posts: 3,627 |
cool I will try the battery stuff first then if non of that works I will take you up on that VSS thing... how much do you want for the sensor
