"What all would you do if money was not an issue". Is this not the case? If money is no issue than i don't know what pistons to go with. I got diamond pistons. Those should work fine. I would bore it sleeve it, I would Buy titanium rods and shave the crank. balance the engine . THis could quite literally keep going and going and going...........no i simply undersand what you mean. IF you want 400whp its recommended to get forged rods and pistons. If you are going to be under that get custom pistons, main bearings and stronger rod bolts. someone else can fill in or recommend something else i missed.
